Twin Hs2 Air Filters
8 replies to this topic
#1 lukepinfield
lukepinfield
  • 49 posts
  • Local Club: 4th Gear Mini Club
Posted 29 June 2011 - 08:24 PM
I have a pair of refurb'd twin HS2's and am thinking about what air filters to use, I have read into trumpets and socks however am unsure if this will provide enough filtering?? or to go with K and N pancakes?? come on guy's what are you running??
#2 bmcecosse
bmcecosse
  • 9,699 posts
Posted 29 June 2011 - 08:46 PM
A 'pancake' filter is no use - but a taper cone filter (like K&N) is ok. Really - a big single carb is better than the twin small carbs -and only means one filter to buy!
#3 Big_Adam
Big_Adam
  • 7,435 posts
Posted 30 June 2011 - 12:03 PM
Says you, I prefer having all 4 cylinders getting a more equal flow of air and fuel.
#4 jaydee
jaydee
  • 8,565 posts
Posted 30 June 2011 - 01:59 PM
Sorry but in that point of view a bigger single one has a smoother flow.
-PS i dont want to open another can of worm bout twins and single carbs-
Edited by jaydee, 30 June 2011 - 02:01 PM.
#5 Cooperman
  • 23,327 posts
Posted 30 June 2011 - 03:48 PM
To answer the original question, the best filters are K & N conical with 'stub-stacks'.
#6 TopCatCustom
TopCatCustom
    Previously known as C4NN0N.
  • 1,134 posts
Posted 30 June 2011 - 04:00 PM
("what he said" smiley that doesn't exist on tmf)
#7 lukepinfield
lukepinfield
  • 49 posts
Posted 30 June 2011 - 05:58 PM
Ok then, what do people think about trumpet socks??
#8 PhilipGCaldwell
PhilipGCaldwell
  • 870 posts
Posted 30 June 2011 - 08:31 PM
Dogs Danglies
#9 twrminisport
twrminisport
    Jesus
  • 913 posts
Posted 30 June 2011 - 11:02 PM
Twin Carbs are better than single. Fact.
Smoother flow in and out of the engine.
Direct lines into the ports so no ineffecency
Read VIZARD. Even he says a good twin setup will out perform single carb setups.
If you tune a set of HS2's right you can get them to perform upto 100BHP.
Im sorry to say this but i cant agree with you here cooperman, PhillipGCaldwell has shown you THE BEST filter design. (The one i told him about :!:)
But you will pay the price.
Pancakes are rubbish. A design that does not bring any air in from the largest face surface yet tries to bring air in from the smallest surface, i.e. round the edges, and then tries to turn the air through 90 degrees into the carburetion system is inefficient and a waste of money leading to power losses.
Jesus
