Steering Wheel Movement
Posted 29 June 2011 - 09:59 PM
hope that makes sense...
Posted 30 June 2011 - 07:48 AM
Posted 30 June 2011 - 09:53 AM
things i would check to see if tight,
-the 4 nuts in the floor holding the steering wrack to the floor,
-the pinch bolt at the bottom of the column(just before it goes through the floor.
and i just going have a general wiggle of the rack and see if it moves
regarding the steering column bushes, if i remember rightly, if you remove the cowling(plastic thing on steering column covering everything up) you should be able to see both bushes??(if someone could clarify me on this)
what year is the car
thanks
Nick
Posted 30 June 2011 - 09:57 PM
and i just going have a general wiggle of the rack and see if it moves smile.gif
what year is the car smile.gif ?
thanks
Nick
hey, thanks for the reply, i checked all the bolts and there all as tight as can be, the pinch bolt at the bottom of the column is moving up with it as well.. its a 1987 mini mayfair
cheers
Mike
Posted 30 June 2011 - 10:04 PM
Posted 30 June 2011 - 10:17 PM
Sounds like your rack is worn out if the pinion can move in and out of its housing. If that's the case then the car is too dangerous to drive. The pinion is supposed to be preloaded. Have someone watch to see if the rack moves when you push and pull the column, if the rack stays still or just barely moves but the pinion that the column is bolted to is moving a lot further your car is going nowhere until fixed.
thats what i was least hoping for
cheers
Posted 01 July 2011 - 04:08 AM
but basically,
drop the back of the subframe down abit(or off to make it really easy, undo the track rod ends, the steering rack U bolts, and it's basically off
goodluck
Posted 01 July 2011 - 07:45 AM
if you've got the engine out , do it now! depending on if your subframe is still on or not, its easy check the haynes manual for the full description of how to do it
but basically,
drop the back of the subframe down abit(or off to make it really easy, undo the track rod ends, the steering rack U bolts, and it's basically off if you can change an engine, you can change a steering rack
goodluck
Right, thanks for all the help, I've dropped the subframe before to change the subfram mounts so I presume it's similar to that, when I buy a new steering rack is there anything else I will need to go with it bushes, rubbers or anything or do they come ready to bolt on?
Posted 01 July 2011 - 07:56 AM
that's it though i believe
Posted 01 July 2011 - 05:00 PM
Posted 01 July 2011 - 08:53 PM
