Cheap And Cheerful Angle Grinder?
Posted 01 July 2011 - 01:04 PM
http://www.wilkinson...r...OHJcT3SpQ==
I need one to remove some metal off my front wings (under the arch). Will it do the job or am I best to steer clear?
Posted 01 July 2011 - 01:08 PM
its not broken tho!
you could go for something like this if you're close to an argos, its bound to break with in a year so you just return it and get another 1 for the next year!!
Edited by danie garry, 01 July 2011 - 01:11 PM.
Posted 01 July 2011 - 01:19 PM
I thought draper stuff was alright? I only need it for a bit of trimming work so it might be worthwhile.
Posted 01 July 2011 - 01:24 PM
It normally is, but that grinder button potion is just silly. I got a £30 one from B&Q. It did bork itself once, turned out a carbon brush was stuck.
Posted 01 July 2011 - 01:25 PM
I had one, it broke after 16 months, still had reciept, took it back and they swapped it for another one. The price had gone up a couple of quid so I had to pay the difference but it's OK.
Cutting discs - toolstation do 10 for around £4.
Edited by icedaddyuk, 01 July 2011 - 01:25 PM.
Posted 01 July 2011 - 01:33 PM
Posted 01 July 2011 - 01:34 PM
Posted 01 July 2011 - 01:38 PM
Posted 01 July 2011 - 01:43 PM
Posted 01 July 2011 - 02:47 PM
This one?
http://www.diy.com/d...=angle_grinders
Comes with a disc as well and got good reviews
that's the one, it's not particulary powerful and will get bogged down on heavy stuff, but it does the job, especially with two year warranty.
Posted 01 July 2011 - 03:03 PM
This one?
i have that one its cut a mini in half and the front end off 3 and sheds loads more still going strong!!!!
Posted 01 July 2011 - 04:02 PM
Is it possible to use the metal grinding disc as a cutting device? As in, to cut about a half inch strip off my wing (under the arches) to give more clearance for the tyres. Sorry if this is a stupid question.
Posted 01 July 2011 - 04:21 PM
Get a pack of thin cutting discs, thinner the better really.
Posted 01 July 2011 - 05:09 PM
Graham
Posted 01 July 2011 - 05:39 PM
I have a Bosch angle grinder that has been used very frequently and still going after 15 years, although the unlock mechainsm has bust, I just use a spanner to lock the spindle instead. I also bought a cheap B&Q jigsaw for £11 thinking 'if it dies i will just buy another one'!! that has also been going strong for around 9 years now!!
I suppose how you treat them also has a big impact on how long they last. Look after them and they will look after you is how the saying goes!
Edited by R1minimagic, 01 July 2011 - 05:41 PM.
