Pedal Height
Posted 03 July 2011 - 03:26 PM
I have used the original pedals but have replaced both master cylinders - a new yellow band brake cylinder and a tin clutch cylinder I picked up at a show. Both appear to be correctly installed and work smoothly but obviously there is a problem somewhere. I suspect that the brake is too high (difficult to tell without seats etc) as the pedal does not travel com pletely to the floor.
I guess that one or other of the cylinders or push rods are incorrect. Could someone tell me the correct pedal height from the floor so that I can narrow down the fault? I would also welcome suggestions on the cause and solution.
Posted 03 July 2011 - 04:00 PM
Plus I didn't really want to cut and shut the brake pedal.
Posted 04 July 2011 - 03:11 PM
Posted 04 July 2011 - 07:26 PM
I would like to get mine sorted too.
Posted 04 July 2011 - 07:57 PM
Posted 04 July 2011 - 08:01 PM
I read it somewhere but I forget the exact details - check the thickness of the brake pedal metal also - not the pedal pad itself, but the shaft, if you get what I mean
If it is thicker than the clutch, it is probably one of these extra cranked pedals (for discs, esp coooper s although might be normal on all discs, I dont recall the exact details)
I have one on my 82 city e but I now have cooper s discs and read that these were a good idea - it works fine.
Posted 04 July 2011 - 09:17 PM
The pedals and brakes are completely original (drums). The master cylinders have been replaced. These should be compatible but clearly either the clutch or brake cylinder (or one of the push rods) is not right.
I need to know the correct pedal height so that I can work out where the fault is. Can someone take a tape measure to their mini?
Posted 04 July 2011 - 10:04 PM
Posted 04 July 2011 - 10:06 PM
Posted 05 July 2011 - 12:56 AM
There's no difference between discs & drums, altering the length of the pushrod is the best solution, but it's obviously safer to extend the clutch's.
Posted 05 July 2011 - 07:49 AM
Posted 05 July 2011 - 09:18 AM
Posted 12 July 2011 - 09:48 PM
Posted 13 October 2011 - 04:34 PM
put a new clutch plate and clutch slave cylinder along with the brake and clutch resevoirs and found that the clutch pedal sits lower than the brake by a good amount
im just going to live with it as i couldnt be bothered with the hassle of taking the pedal box etc back out
