Spax Coilovers!
11 replies to this topic
#1 Leon_mini
Leon_mini
  • 166 posts
Posted 04 July 2011 - 12:10 PM
Looking into buying some coilovers and have been offerd a pair (front) but they are un sure if they are lowerd or standard
could anyone tell me the measurments of either one, or both?
thanks
#2 oliver122
oliver122
  • 1,007 posts
Posted 04 July 2011 - 12:33 PM
thanks
aren't coil overs adjustable , are you on about shock absorbers by any chance ?
#3 Leon_mini
Leon_mini
  • 166 posts
Posted 04 July 2011 - 12:38 PM
thanks
nope, pretty sure you can get, adjustable, standard height and lowerd, unless im wrong..
#4 Jayme 1275
Jayme 1275
  • 488 posts
Posted 04 July 2011 - 01:29 PM
I have a set if you can give u's 15 mins il check you just want the overall length ?
#5 Leon_mini
Leon_mini
  • 166 posts
Posted 04 July 2011 - 03:27 PM
yhh that would be great, if you could :D
#6 Cian 'the pain' MPI
Cian 'the pain' MPI
  • 163 posts
  • Local Club: mini-chat.co.uk
Posted 04 July 2011 - 08:07 PM
Coilovers are the same height, rang gaz and they confirmed this a while ago, could be the brackets that are different though
#7 100ev8
100ev8
  • 622 posts
Posted 04 July 2011 - 08:27 PM
i thought it was the shock that was different ?
#8 Cian 'the pain' MPI
Cian 'the pain' MPI
  • 163 posts
Posted 04 July 2011 - 08:33 PM
nope sure that is the point of coilovers, you can get standard or shorted shockers but coilovers are all the same or so i believe!
#9 miniallsort
miniallsort
  • 4,723 posts
Posted 05 July 2011 - 12:43 AM
yeah u can get lowered or standard spax coil overs
#10 Cian 'the pain' MPI
Cian 'the pain' MPI
  • 163 posts
Posted 05 July 2011 - 10:24 AM
But if they are lowered height does that mean that they are shortened? This would not mean that they could go any lower than a 'standard' height coilover it would only mean that when the spring is on full rebound its not bouncing loose in the coilover
#11 Ethel
  • 26,151 posts
Posted 05 July 2011 - 11:16 AM
Lowered would mean shorter when closed up (bump). You're right in thinking that the ride height is largely down to the spring - and how much of the coil over damper sticks out above & below it.
Spax list std & lowered coilovers: g893, g894, g895, g896
Larkspeed claim the difference in ride height is an inch.
#12 Cian 'the pain' MPI
Cian 'the pain' MPI
  • 163 posts
Posted 05 July 2011 - 01:22 PM
Wen i had mine at the lowest they nocked off the bracketry and the ball joints were seriously angled, if you want it low there is a price to pay, i wouldnt get coilovers purley to deck it i would stick with hi los etc but coilovers are easier to set up and simpler set up and handling is awsum imo
