The headlight flasher does not work when I pull the stalk towards me. I have checked the fuse (all seems fine). The headlights & sidelights work but not the flash. Could it be the salmony pink / orange relay unit that is faulty or is it something else?
I have tried it with the ignition on & the headlight switch turned on but with no joy.
Is there someway of testing the relay switch to see if that is functioning correctly?
Most importantly is this an MoT failure point??????????
Edited by Ocado Man, 04 July 2011 - 04:53 PM.
