It's a 95 spi with a stage one exhaust and a worked head from a mightymini, and sometimes is has a bit off oomf.
Sometimes it feels like a badly tuned 998.
It feels like the ECU is auto-calibrating the fuel map every time i start up+drive, the car varies in power quite a bit, even with the same throttle position and load, over about a couple seconds each time. It actually feels like someone's messing with the fuel mix screw on a carb as i drive...
Just wondering if this was normal, it seems logical to me that the ECU should have a map already built in and that it'd know how much fuel to put in at all load levels/revs/throttle position/temp/air temp etc. Also there's a blue/green wire under the steering column which is frayed/slightly burnt, don't know if that's anything to do with it.
If I were to guess what it was, i'd say that the permanent live to the ECU which presumably keeps the flash memory running was faulty. But that's me using computer knowledge rather than actual ECU knowledge.
Also the exhaust is always really sooty and my fuel economy is shocking, around 20mpg.
Any ideas?
EDIT: Spelling, sorry :/
Edited by northy, 17 July 2011 - 04:44 PM.
