Caster Camber Toe
Posted 05 July 2011 - 10:02 PM
Posted 05 July 2011 - 10:06 PM
Posted 05 July 2011 - 10:21 PM
Posted 05 July 2011 - 10:22 PM
how low is it?? - if its sitting on the bump stops you will get negative camber....
its standard height
Posted 05 July 2011 - 10:25 PM
its standard height
Would imagine that if everything is original then, no, it wont be at standard height as the rubber cones would have collapsed (last about 10 years) and the car will be sitting on the bump stops.
As you lower the front of the car... negative camber increases.
Check clearance of the front arm to bump stop.
Edited by icklemini, 05 July 2011 - 10:28 PM.
Posted 05 July 2011 - 10:26 PM
its standard height
You got all new springs fitted then?
not that old but not new
Posted 05 July 2011 - 10:27 PM
I do it in Northamptonbut need some one to set it up, i live in romford rm1. if you know anyone near it would be much appreciated
Posted 05 July 2011 - 10:30 PM
its standard height
i have 175 50 13 wheels and i have proberly about 2 inches between it and the zeemax arches
Posted 05 July 2011 - 10:34 PM
I have 175 50 13 wheels and i have proberly about 2 inches between it and the zeemax arches
Means nothing am afraid...
Bump stop clearance needs to be checked... then you will know if its sitting on the bump stops and thus is leading to your negative camber issues...
or as Roy said earlier.. someone has fitted longer arms... messed around with the tie rods.. etc.etc
