Blue Smoke...thin Oil?
Posted 06 July 2011 - 06:29 AM
I replaced the valve stem seals and lapped the valves.
Took the car out for a run last night (first since engine has been in) and it was moking under load (white/blue) The engine had been standing for a long time before I got it so this is probably the first time it's been run in a few years.
Could the smoke be due to thin oil 10w/40 semi synthetic seeping past rings/seals? Could it be ill adjusted timing/carb and overfuelling?
Before I pull the engine out to replace rings I was hoping for some other opinions.
Plan was to change oil to 20w/50 and get the car rolling roaded to rule out ignition/fueling.
Any ideas?
Matt
Posted 06 July 2011 - 06:38 AM
did you clean the carbon ring from the top of the cylinder bore? if so just run it for a few miles to build up a seal, you could doo a compression and leak test.to see the condition of the engine
i would certainly change back to 20/50 with a new oil filter , semi synthetic sound like beauty treatment
john
Posted 06 July 2011 - 06:40 AM
Matt
Posted 06 July 2011 - 10:54 AM
Posted 06 July 2011 - 11:00 AM
Posted 06 July 2011 - 11:28 AM
Posted 06 July 2011 - 11:32 AM
Posted 06 July 2011 - 11:42 AM
Matt
Posted 06 July 2011 - 11:49 AM
Yes to the oil, hell no to the additive...worth putting 20w/50 mineral oil and 'stop smoke' additive for the time being?
Posted 06 July 2011 - 12:13 PM
Posted 06 July 2011 - 12:17 PM
Posted 06 July 2011 - 12:18 PM
is 20w/50 oil ment for all mini's as i'm having the same problem with mine and i'm using 10w/40
10/40 is good for autos, but 20/50 is good for manuals. Some use 10/40, but for "tired" engines like the OP, 20/50 could potentially reduce oil consumption rates. Note i said reduce the rate - it will not "fix" the problem (unforunately).
Edited by L400RAS, 06 July 2011 - 12:19 PM.
Posted 06 July 2011 - 03:33 PM
Posted 06 July 2011 - 04:12 PM
20w50 mineral oil is needed by the gearbox as well as the engine.
I best change the oil once more then
Posted 07 July 2011 - 07:13 AM
Car is still smoking under load
