How Do I Remove Windscreen Wiper Motor
6 replies to this topic
#1 lostboys
lostboys
  • 14 posts
Posted 12 July 2011 - 05:16 PM
Hi
Tried to remove the wind screen wiper motor on my rover mini city E 1990.
I have undone nut on top and remove it from bracket but don't know how to pull cable out of end.
#2 R1minimagic
R1minimagic
  • 4,660 posts
Posted 12 July 2011 - 05:25 PM
Do you mean the electrical 5 pin plug? They are a pain in the a**e to get off as the connections corrode, usually resulting in the need for a new park switch as the thing is very delicate...
#3 benjy_18
benjy_18
  • 1,038 posts
  • Local Club: LSMOC
Posted 12 July 2011 - 05:37 PM
i think he means the worn screw connected to the wiper arms.
i took mine off by lifting the wiper blades off the screen (as you would to clean the windows) and just pulling the cable through. just do it slowly so that the wiper arms dont flick back because they will turn as you pull out the cable.
#4 lostboys
lostboys
  • 14 posts
Posted 12 July 2011 - 06:05 PM
Hi Benjy
Yes the worm drive end, thank you for that tip will give it a go.
#5 craigr91
craigr91
  • 429 posts
  • Local Club: nwminiclub
Posted 09 March 2014 - 01:17 PM
Thread revival I know but saves a new post:
So is just a car of pulling the motor away, I've moved the electric connection n undone the nut
Also how do you remove the things on the scuttle panel?
Many thanks
Edited by craigr91, 09 March 2014 - 01:18 PM.
#6 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 09 March 2014 - 02:44 PM
So is just a car (case?) of pulling the motor away, I've (re?)moved the electric connection n undone the nut
It is more than undoing the big nut to the rack tube.  WIth the nut to the tube loosened you remove the screws on the flat plate forming the top of the wiper motor.  Lift the plate off and you will see a crank arm and a gear that drives it.  Remove the crank arm so you can separate the wiper motor from the rack tube.  That will you to remove the wiper motor once it's mounting bracket is removed.  (This will make more sense once you remove the plate and/or look at the picture below).
Do you mean the wheelboxes?  The things the wiper arms connect to?  If so, you remove the wiper arms, then spray the nuts below them with penetrating oil and remove the nuts.  With the nuts removed you press the wheelboxes down through the scuttle into the engine bay.  Don't do that until you have removed the motor as the rack tube needs to move "down" along with the wheelboxes.
#7 craigr91
craigr91
  • 429 posts
Posted 09 March 2014 - 03:08 PM
Brilliant, I'll give that a go, thanks
