306 Gti-6
6 replies to this topic
#1 starletman
starletman
  • 249 posts
Posted 14 July 2011 - 09:09 AM
Does anyone know if this engine gearbox combo will fit in a mini.I picked one up this morning and like the idea of 167bhp with a 6 speed gearbox.
#2 charm_muppet
charm_muppet
  • 77 posts
Posted 14 July 2011 - 09:11 AM
Anything can be made to fit, the 306 isnt the obvious choice though.
#3 chrisj
chrisj
  • 283 posts
Posted 14 July 2011 - 11:53 AM
It's a big old unit with a big 6 speed box, with the angle the engine needs to sit at i'd say it was a no go, but anything can be done with time and patience.
Main problems will be radiator clearance, and gearbox size.
If the gearbox was a problem due to its size you could use the xsara vts 5 speed box, fits straight on and has the ideal ratios to work with the 6 engine.
Chris
#4 mini93
mini93
    He's just too casual!
  • 8,615 posts
Posted 14 July 2011 - 05:19 PM
im simply going to say no... its mahoosive, and to even fit it in a 205 which is wider than a mini, you have to ditch the 6 speed box... theres better engines out there to use
#5 bmcecosse
bmcecosse
  • 9,699 posts
Posted 14 July 2011 - 06:38 PM
Maybe in the back seat........
#6 Kam
Kam
    Straight to the Point
  • 4,140 posts
  • Local Club: 16vMini club
Posted 14 July 2011 - 07:04 PM
Gti-6 in a pug 205 goes in very well, hopefully if Sam is about he'll let you know how well :cry:
In a mini, as above, anything will fit, all depends on how deep your pockets are or how clever your mind is and how the car is gonna look
Would be a different choice from the norm but are good engines though
#7 valve bounce
valve bounce
  • 694 posts
Posted 14 July 2011 - 07:43 PM
im going to say it will be very very difficult but if you want to try, why not. the thing is it is a very large unit it doesn't even fit in the 306 properly, there is less lock on the steering that the standard 306 and that's just so the gearbox and wheel don't touch on full lock
