Ignition Wires
4 replies to this topic
#1 ralphbrown15
ralphbrown15
  • 36 posts
Posted 14 July 2011 - 10:27 AM
I have an Austin Mini Mayfair and I'm changing the ignition switch so its dash mounted.
What wire is what? Theres four, White, White/red, brown and green/white
#2 jelboy89
jelboy89
    Formally known as jr4sr4eva
  • 169 posts
Posted 14 July 2011 - 10:39 AM
best thing to do is use a test lamp and check terminals for power, i am sure the brown goes to starter selonide
#3 Ethel
  • 26,057 posts
Posted 14 July 2011 - 11:15 AM
Brown = 12v supply
White/green = accessory (1st key position, for radio etc)
White = ignition (2nd key pos'n)
White/red = starter
#4 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 14 July 2011 - 02:29 PM
It should be mentioned that it is both illegal and extremely, unbelievably dangerous to set your car up so that it is possible for the engine to be running while the steering lock is engaged. It's also the law that cars from after around 1973 or so have an interlocked immobiliser, this is what the steering lock is for.
#5 ralphbrown15
ralphbrown15
  • 36 posts
Posted 14 July 2011 - 11:05 PM
Cheers Ethel
And Dan, I dont have a steering lock all together, but I will get one if needs be
