Washer Jets
6 replies to this topic
#1 Jayme 1275
Jayme 1275
  • 488 posts
Posted 14 July 2011 - 03:04 PM
hi anyone got any sugesstions the pump is working in the boot and the wipers work. its a mpi mini i had a look all the pipes runing under the scuttle are clear so no blockages
anyone ever had this problem before?
#2 maggies_minder
maggies_minder
    TMFs New official Spamster
  • 4,393 posts
Posted 14 July 2011 - 03:06 PM
are the actual squirter jets blocked?
do you have water in the bottle in the boot?
#3 Jayme 1275
Jayme 1275
  • 488 posts
Posted 14 July 2011 - 04:18 PM
yea washer bottle in the boot i dont think the jets are blocked because there isnt even any fluid in the pipes leading to them
#4 maggies_minder
maggies_minder
  • 4,393 posts
Posted 14 July 2011 - 04:22 PM
are you sure the pumps working?
#5 R1minimagic
R1minimagic
  • 4,660 posts
Posted 14 July 2011 - 04:32 PM
Pipes could be blocked in the middle somewhere, not got an air compressor to blow them out?
#6 tommy boy
tommy boy
  • 197 posts
Posted 14 July 2011 - 09:19 PM
Hi
I think thatif the jets are blocked, the pump can`t clear the air from the pipes. I normally use a single strand from a wire brush if I have no air line.
Stick it in and just jjjjjjiggle it about Arcwright. Normally works
#7 Jayme 1275
Jayme 1275
  • 488 posts
Posted 17 July 2011 - 01:29 PM
Thanks for the suggestions guys the you can hear the pump working In the boot. Il try clearing the jets out and yea I have a air compressor but some fool living in the house lost the hose and gun so il have to try a needle just
