Offside Rear Light And Sidelight Not Working
12 replies to this topic
#1 RossKnight
RossKnight
    One heck of a member
  • 2,539 posts
  • Local Club: JKSA MOC
Posted 15 July 2011 - 08:12 PM
Model: city e
Year:1992
Just noticed my drivers side rear light isn't working, nor is the same side drivers light
Everything else is working fine, reverse light, brake light, fog, dipped beam, full beam + spots
What do I need to check? Any idea what fuse this runs on, I dont have my haynes with me.. I'm really stumped, never really thought about electrical problems before.
#2 bmcecosse
bmcecosse
  • 9,699 posts
Posted 15 July 2011 - 10:36 PM
Fuse blown - but you need to ask why?
#3 RossKnight
RossKnight
  • 2,539 posts
Posted 16 July 2011 - 08:08 AM
Thought as much.. off hand do you know which fuse it is?
I'm going to have to look real hard for something shorting it now..
#4 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 16 July 2011 - 09:03 AM
More likely to be bad earth if all lights in one cluster are not working, on the other hand it could just be the bulb ?
PS, if it were the fuse then all side lights would be inoperative as would be the instrument lights.
Edited by Guess-Works.com, 16 July 2011 - 09:04 AM.
#5 AVV IT
AVV IT
    I am a shed dragger.
  • 6,122 posts
  • Name: Dave
Posted 16 July 2011 - 09:31 AM
As above, the fuse for the tail lights (15 amp in line fuse behind the carb/air filter with red/white wire) supply's both tail lights as well as the dash lights, so if your nearside tail light is still working, then the fuse isn't likely to be the problem. What do you mean by the term "drivers light" on the same side that is also not working?? :D
#6 RossKnight
RossKnight
  • 2,539 posts
Posted 16 July 2011 - 08:40 PM
I meant the side light on drivers side, think I might go check out there now, see for definate in the dark which are working and which are not.
#7 matt615
matt615
  • 923 posts
Posted 16 July 2011 - 09:10 PM
That's true on earlier Minis, but they changed the wiring on later Minis, with the side/tail lights on each side of the car running off separate fuses.
Ross as your car is a 1992 model it would have this later wiring loom. So your problem probably is a fuse, either it's blown or has bad connections.
Edited by matt615, 16 July 2011 - 09:15 PM.
#8 RossKnight
RossKnight
  • 2,539 posts
Posted 16 July 2011 - 10:08 PM
Hmm strange, car hasn't moved or anything since last night, but now it's just the rear tail driving light that's out, so bulb?
Need to check all wires, fuses and earths tomorrow
#9 Timtom
Timtom
  • 2,143 posts
Posted 16 July 2011 - 10:22 PM
If you need a bit dude i've probably got it? and i'm only down the road :)
(though no transport i'm afraid!)
#10 RossKnight
RossKnight
  • 2,539 posts
Posted 16 July 2011 - 10:38 PM
If you need a bit dude i've probably got it? and i'm only down the road ;)
Cheeers, yeh not far at all, I'll have a look tomorrow :)
#11 minimender
minimender
  • 1,589 posts
  • Local Club: M.M.M.
Posted 16 July 2011 - 10:43 PM
Could be the connectors in the boot
#12 RossKnight
RossKnight
  • 2,539 posts
Posted 18 July 2011 - 07:20 AM
Changed the bulb, still not working.. The connector in the boot is fine, I have about 15 minutes before MOT.
#13 matt615
matt615
  • 923 posts
Posted 18 July 2011 - 08:05 AM
Could be a bad connection under the bonnet. I think there is a connector on the bulkhead where the wire for the tail light and side light spilit off to the front and back of the car. If this connection is dirty it would explain why the side light wasn't working but fixed itself, and why the tail light isn't working.
