Good Roll Cages
17 replies to this topic
#1 MJWarren
MJWarren
  • 705 posts
  • Local Club: DCMOC
Posted 17 July 2011 - 04:50 PM
Where is a good place to get a bolt in cage from?
thanks
#2 Artful Dodger
Artful Dodger
    " I AM THE SPECIAL ONE"
  • 4,435 posts
Posted 17 July 2011 - 04:53 PM
mini sport stock saftey devises roll cage, they are FIA approved and have all of the variatys available, at a good price
its worth it!
Harri
#3 wolfie
wolfie
  • 1,149 posts
Posted 17 July 2011 - 05:11 PM
Minisport and minispares stock safety devices
I prefer roll centre door bars over the safety devices, there made to the same FIA standards and you can buy direct and there cheaper!
http://www.rollcentr...ional_spec.html
#4 Cooperman
  • 23,357 posts
Posted 17 July 2011 - 06:49 PM
I always used Safety Devices in the past, but the Roll Centre ones are also excellent I've heard.
So long as they are FIA Approved they'll be fine for competition so long as the fitting is in accordance with the MSA 'Blue Book' requirements.
#5 Artful Dodger
Artful Dodger
  • 4,435 posts
Posted 17 July 2011 - 08:24 PM
sorry for a thread hijack but are the roll center door bars comapable with safety devices roll cages ??
#6 wolfie
wolfie
  • 1,149 posts
Posted 17 July 2011 - 11:09 PM
sort of
Roll centre have welded flanges that bolt together, the safety devices clamp round the tube
You could fit roll centre door bars if the cage measurments are the same as roll centre but you would have to weld the flanges to the cage
http://www.merlinmot...oduct_info.html
Edited by wolfie, 17 July 2011 - 11:10 PM.
#7 R1mini
R1mini
  • 1,387 posts
Posted 18 July 2011 - 09:11 AM
sort of
If you make any welded modifications you will lose the certification
David
#8 wolfie
wolfie
  • 1,149 posts
Posted 19 July 2011 - 09:52 AM
Depends if he wants the msa certification, main thing is the original construction is to FIA spec if its for a road car then there is no issue and a far better prospect thyan buying from the likes of Geronimo or what ever there called
Edited by wolfie, 19 July 2011 - 10:00 AM.
#9 TopCatCustom
TopCatCustom
    Previously known as C4NN0N.
  • 1,134 posts
Posted 19 July 2011 - 11:19 AM
Yeah dont buy from Geronimo!
I can't stand those awful looking "clamps" that you get for door bars etc on safety devices and some other cages, welded brackets are much better, neater and stronger IMO.
#10 steverose
steverose
  • 229 posts
Posted 19 July 2011 - 12:23 PM
I prefer the clamps, it means you can take the bars off to get seats in, or if you just want them out of the way if your using it as a road car (dont think the missis would like climbing over them in a dress). But equally you can never be sure how good the welding is, so while it may look good it may be much weaker than the bolted in type problem is you wont find out until you need it the most.
#11 TopCatCustom
TopCatCustom
  • 1,134 posts
Posted 19 July 2011 - 01:18 PM
You can unbolt both types very easily, this is my prefered type:
These are the type I think are a bit horrible, you can make out the one on the drivers side easier:
#12 benjy_18
benjy_18
  • 1,038 posts
  • Local Club: LSMOC
Posted 19 July 2011 - 01:44 PM
heres another vote to buy from anywhere except geronimo! aweful service and the cages dont fit very well. i may as well made my own the amount of work ive done to it.
#13 Cooperman
  • 23,357 posts
Posted 19 July 2011 - 03:13 PM
None fit as well as the Safety Devices ones.
Don't forget to use proper padding on all the front bars. The installation of a roll cage really does make the inside much less safe in an accident unless you are wearing a crash helmet, so unless you think you may be likely to roll your car it is probably not a wise thing to install and never install one unless there are proper 4-point located full harness belts to motor-sport specifications fitted as well. Hit your head on a roll cage in an accident and it could easily be 'Goodnight Vienna'.
#14 wolfie
wolfie
  • 1,149 posts
Posted 19 July 2011 - 04:06 PM
Sorry thats rubbish, Roll Centre fit Just as well as safety devices i know ive had both and currently have roll centre as i like there dog leg door bars better.
I do agree the safe thing to do is low mounted buckets with harnesses and roll cage padding, i do use padding when i go to a track day or drag racing but take it off when its on the road as i dont like the look regardless of the safety aspect.
Edited by wolfie, 19 July 2011 - 04:13 PM.
#15 MJWarren
MJWarren
  • 705 posts
  • Local Club: DCMOC
Posted 19 July 2011 - 05:19 PM
Thanks guys, ive seen the roll centre ones and i think i might go for one. Look like they fit well enough to me, but we will see when i buy one.
Matt
