Rod Change Gear Selector
11 replies to this topic
#1 monster_mini
monster_mini
  • 981 posts
Posted 19 July 2011 - 11:12 AM
hi everyone :o
so the problem-
gear selection is perfect, it selected every gear perfectly :thumbsup: but when in any of the gears, the gear stick could move forwards and backwards about an inch at your hand having no effect to the gearbox ?
so does this mean the bush that the other part of the rod change selection which attaches to the gear box was shot?
i am currently swapping my engine over to my 1275 and want to cure this problem at the same time, so i have remover the gear selector mechanism too, and to me the bracket which bolts it to the car doesn't look right :/
if anyone could give me some guidance that'd be epic :)
cheers
Nick
#2 R1minimagic
R1minimagic
  • 4,660 posts
Posted 19 July 2011 - 11:25 AM
It looks all bent on the right hand side to me, the part with the bobbins should be straight!
#3 minimat
minimat
  • 690 posts
  • Local Club: anglian mini club
Bracket is bent!
#4 minimat
minimat
  • 690 posts
Posted 19 July 2011 - 11:26 AM
you beat me by second's r1magic!!
#5 R1minimagic
R1minimagic
  • 4,660 posts
Posted 19 July 2011 - 11:32 AM
There should be a gap about 1 cm between the alloy casing and the bracket!
#6 monster_mini
monster_mini
  • 981 posts
Posted 19 July 2011 - 08:55 PM
ahh! :P any chance of a photo of either of yours (or anyone elses) to show how it should be so i can straighten it :)
#7 R1minimagic
R1minimagic
  • 4,660 posts
Posted 19 July 2011 - 08:58 PM
Got this one on ebay, not the greatest of photos i'm afraid!
http://cgi.ebay.co.u...=STRK:MESELX:IT
Edited by R1minimagic, 19 July 2011 - 08:59 PM.
#8 Topaz
Topaz
  • 52 posts
  • Local Club: Derbyshire Classic Mini Owners
Posted 19 July 2011 - 09:38 PM
A drawing here from the Somerford catalogue
http://www.somerford...x...page&id=152
Mike
#9 monster_mini
monster_mini
  • 981 posts
Posted 20 July 2011 - 06:33 AM
cheers :) so, if i'll bend the bracket straight again(well not straight, but to where it should be) ....
but will this cure my problem?
is there any bushes or anything that wears out inside the rod change mechanism it'self ?
cheers
Nick
#10 Ethel
  • 26,074 posts
Posted 20 July 2011 - 10:33 AM
Just make the bend on the left a right angle again. Mine is running smoothly on bits of 15mm copper pipe, but I think you need to check all the pins in the selector rod are tight & the steady rod is screwed on solidly too.
#11 monster_mini
monster_mini
  • 981 posts
Posted 20 July 2011 - 10:34 AM
yeah will do :) okay thanks :P
#12 monster_mini
monster_mini
  • 981 posts
Posted 25 July 2011 - 11:27 PM
just to let you know how i got on, and for future information for anyone else, i bent it so the left side was 90 degrees, but it just wouldn't line up like it was still to wide, so i had a look through all the parts catalogues i have, and in SC's GIANT!!! book, theres a picture of the bracket, and it actually bends to the left on the left side aswell..if that makes any sense :) either way its all sorted now :thumbsup:
thanks
