Condition: GOOD
Price: £250
A sad day but it looks like I'm never going to use it so may aswell spread the love!
What we have here is the main guts of the Rayvern Hydraulics adjustable suspension kit developed especially for the original mini. Essentially the kit when complete gives you in car adjustable HiLo's, raising the front or rear of the car with the flick of a switch (just like in a Snoop Dogg video, biatches aint included).
Included is everything you see in the photo, which is the main pump/tank/actuator setup, 4 valve distribution block, main unit to distro block hose, and the 2 hydraulic rams for the rear.
What will need to be be acquired yourself to complete the kit is the front rams and hoses for the distro block to each ram, these are all still available from Rayvern (I've checked, think it's about £180 for the front rams (pair) and another £100 for the hoses, although I reckon any hydraulic engineers could knock up some hoses for less!). Another option is to blank two of the valves and just run it as a rear only set up! Also you would need to knock up the wiring loom, a wiring diagram is available from Rayvern also.
Remember a complete kit new from Rayvern is around the £1300 mark so although this needs some work it'll still get you bouncing for less than half that completed.
£250 No Offers
Cheers!
P.S. Here is Marc Bakers rayvern equipt mini strutting its stuff, sure he wont mind me using this video as he is the dude!
