Lcb Manifold And Driveshaft
8 replies to this topic
#1 jcollingwood
jcollingwood
  • 53 posts
Posted 22 July 2011 - 09:44 AM
i have just fitted a new manifold to my mini and the center branch is extremly close to the drive shaft... ( pic shows clean metal on the drive shaft where it was rubbing ) after speaking to someone they told me that they are a tight fit, however how tight is tight? at the moment i have mannaged to creat a minimal gap between the two. if you have any ideas please share (: (:
#2 Big_Adam
Big_Adam
  • 7,435 posts
Posted 22 July 2011 - 10:14 AM
You got the rest of the exhaust on at all? As you might have shifted things about.
Also on my Freeflow on my 998, I had a bracket at the bottom to hold it, so you might be able to botch something there as there is a exhaust mount on the back of the gearbox.
#3 Tommyboy12
Tommyboy12
  • 2,254 posts
Posted 22 July 2011 - 10:46 AM
My LCB doesnt sit anywhere near the driveshaft. Its a tight fit yeah but theres a good bit of clearance. Have you pushed it far enough into the link pipe?
#4 AlexMozza
AlexMozza
  • 1,248 posts
  • Local Club: Not Yet
Posted 22 July 2011 - 11:22 AM
I have about 10-15mm space between the manifold and the inner CV
#5 jcollingwood
jcollingwood
  • 53 posts
Posted 22 July 2011 - 11:58 AM
all the exaust is fitted on and i have tried to pull everything to the rear of the car, hence pulling the centre pipe away from the driveshaft. this has only given about 2mm clearance. i have also tryed levering the centre brance of the manifold and getting the pipe further into thw y-piece.. :S puzzled as to what else i can do.
the final conclusion i keep coming too is that the product is either incorrect or faulty (pipe bent incorrect).
this is the lcb that i got and have fitted:
http://www.minisport...PHBSPD708M.html
its a 1275cc engine that i have. can any of you see any problems or any suggestions.
#6 jcollingwood
jcollingwood
  • 53 posts
Posted 22 July 2011 - 08:23 PM
anyone have any ideas?
#7 abe46
abe46
  • 431 posts
  • Local Club: South Devon Mini Club
Posted 22 July 2011 - 08:27 PM
iv got the same LCB and mine was twisted. Personal experience - Minisport exhausts are rubbish!
I will be replacing mine tomorrow with a Maniflow LCB which will be a better fit :thumbsup:
My suggestion would be to return it to minisport and buy something else!
#8 jcollingwood
jcollingwood
  • 53 posts
Posted 22 July 2011 - 08:42 PM
http://www.minisport...info_LM004.html
what this one?
i have been out working on it all day. i got told the best way to move them was to losen the manifold off the head then fit everything and do the manifold bolts up last. managed to do this and have about 3mm of clearance... would you say thats enough.?
#9 abe46
abe46
  • 431 posts
Posted 22 July 2011 - 08:46 PM
http://www.minisport..._LM004S11R.html
I have got that one to put on as i have a maniflow y-piece, link pipe and back box aswell :thumbsup:
I am not sure how much clearance iv got, but i will check tomorrow morning before i get the minisport one off and let you know!
As long as it doesn't touch the driveshaft i would assume it is okay. But make sure you get a manifold to gearbox bracket so it doesnt move about!
