998 Camshaft 286 Or Mspd 3
12 replies to this topic
#1 1990minicity
1990minicity
  • 54 posts
Posted 23 July 2011 - 08:04 PM
Very fast road 998.
big valve cooper head etc big HIF44
should i go with a kent 286 or a Morspeed MSPD Phase 3 trackday cam? or even a kent 286 scatter?
Ta
#2 minimender
minimender
  • 1,589 posts
  • Local Club: M.M.M.
Posted 23 July 2011 - 08:26 PM
Very fast road 998.
Ta
I wouldn't go any more that a 276 for the road
Loose a bit at the top end but gain a lot mid range I've found
just my opinion
#3 PhilipGCaldwell
PhilipGCaldwell
  • 870 posts
Posted 23 July 2011 - 08:42 PM
if its just a trackday toy then 286, RacerPete built a 998 with a 286 and I think he loved it
I have a 276 in mine and its good, bit lumpy below 1500 revs but very driveable
#4 minimender
minimender
  • 1,589 posts
Posted 23 July 2011 - 08:45 PM
Think you'll find the lumpyness is down to ignition timing being too retarded at low revs.
Plenty of advance down there and she'll tick over like a baby
#5 twrminisport
twrminisport
    Jesus
  • 913 posts
Posted 23 July 2011 - 09:19 PM
Interesting. I would probably go for the Trackday cam as its a much more modern cam profile and produces the same inlet lift as the 286. However the exhaust lift is actually less than the 276. Seems to me its a tradeoff.
PhillipGCaldwell: You shouldnt have that issue when your megajolt is fitted with a decent map in place :thumbsup:
Edited by twrminisport, 23 July 2011 - 09:25 PM.
#6 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,145 posts
  • Name: Sean
Posted 23 July 2011 - 09:28 PM
I'd have thought a 286/phase 3 would have been a bit heavy for a 998, over cammed for the sake of being over cammed.
Unless you're running a huge and I mean huge ££££ spec motor a cam that heavy would be a waste. As already said a 276 would be as much as I'd like to use on a 998.
#7 1990minicity
1990minicity
  • 54 posts
Posted 23 July 2011 - 09:43 PM
It will be fairly heavy spec wise, Im going to fully lighten the rods crank etc and have straght cut drops etc.
What do you think?
#8 Cooperman
  • 23,315 posts
Posted 23 July 2011 - 09:48 PM
Built a 998 with a 286, a 12G295 head at 10.8:1 CR, twin 1.21" SU's, etc.Power was good and peaked at 6500 rpm, but almost nothing useable below about 3500 rpm. Had to fit a low final drive to ensure the clutch would last at least for a short while. Good class-winner on Historic events, but not really any good on the road. Swapped that engine for a 970 Cooper 'S' lump with same cam, but twin 1.5" SU's and gained 10 bhp at 6600 rpm. Again nothing below about 3500 rpm and after fitting a SC CR box had to use a 4.1:1 final drive. It didn't 'arf rev though.
#9 Shifty
Shifty
  • 13,145 posts
  • Name: Sean
What do you intend to use it for?
If its just gonna be a trackday weapon then give it a go, but for road use its gonna be a pig to use.
#10 1990minicity
1990minicity
  • 54 posts
Posted 23 July 2011 - 09:54 PM
How low final drive?
#11 minimender
minimender
  • 1,589 posts
Posted 23 July 2011 - 09:55 PM
As Shifty says
286 will rev but you will have to rev it to get any power. Bigger isnt always better, the motor will be very lumpy below 3000 and maybe higher.
It will use gallons of fuel as well,......... MG cam is good up to a higher state of tune than you would think
If you have big valves and a ported head with HIF 44 you can actually loose power over a well ported head with standard valves and an inch and a half carb.
Very tricky this tuning lark, dont make any sense sometimes.
#12 minimender
minimender
  • 1,589 posts
Posted 23 July 2011 - 09:58 PM
Give you an example.
I once ran an 1100 clubman which was standard and had a 3.6 diff
My mate had a tweaked 1275 with a 3.4 diff
My 1100 was quicker getting away and was faster on the motorway.
#13 minilee94
minilee94
  • 3,523 posts
Posted 23 July 2011 - 10:41 PM
hi mate i pm'd you but no reply just wonderd if you got pm
