Door Locks Crunching
2 replies to this topic
#1 studavis
studavis
  • 65 posts
Posted 24 July 2011 - 03:13 PM
Model: Mayfair
Year: 1984
My drivers side door lock is playing up slightly. When I go to lock it with the key, it turns to the right, and just before the end, it 'crunches' when completing the turn. The door locks but not correctly, as if you press teh button hard and a number of times, the door eventually opens. Any ideas?
I've taken the side of the lock off (accessible when you open the door) and WD40'd it and that seems to have helped a bit.
Thanks in advance ;D
Edited by studavis, 24 July 2011 - 03:40 PM.
#2 studavis
studavis
  • 65 posts
Posted 25 July 2011 - 10:11 AM
Anyone? Thanks.
#3 freshairmini
freshairmini
  • 1,718 posts
Posted 25 July 2011 - 10:30 AM
Anyone? Thanks.
I have a similar problem on mine, they are new and I forgot to put any oil or grease on them and the drivers side crunches when I unlock mine. so I would image that's why for you And me, unless something has broken, can't think what tho.
Could try some of that white spray grease stuff, could help.
If you take your door card off you'll get a better view of it with out having to unbolt anything.
