Left Hand Thread Torque
10 replies to this topic
#1 maccers
maccers
  • 1,875 posts
  • Local Club: LSMOC
Posted 24 July 2011 - 03:47 PM
Question: How do you measure the tightness of a left hand thread? I need to remove both rear hubs to replace the studs on them for longer ones, and the left had side is a left thread.
My Draper Torque wrench allows use in both directions, ie do up, and un do, my Halfords one only allows traditional "do up" direction.
I am sure my Draper tool does not click on traditional "un do" which will I guess be "doing up" the left hand side. It does click on the normal "do up" way.
So just wanted to know how to measure it, as its quite a key part I will be removing!
Richard.
#2 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 24 July 2011 - 04:15 PM
Does your halfords one not have a push through ratchet ?
#3 maccers
maccers
  • 1,875 posts
  • Local Club: LSMOC
Posted 24 July 2011 - 04:45 PM
Just looked at it has a small circlip holding the drive on - assume this is the bit i need to reverse?
Edited by maccers, 24 July 2011 - 04:47 PM.
#4 icklemini
icklemini
  • 2,982 posts
Posted 24 July 2011 - 04:49 PM
no - usually the 1/2" bar where the socket slides onto will push through to the other side...
#5 maccers
maccers
  • 1,875 posts
  • Local Club: LSMOC
Posted 24 July 2011 - 04:51 PM
Nope, its like a solid wheel / grip on one side, with a 1/4" drive on other. It only go to 44LBS - assume the rear axle nut it maybe 60+ lbs?
Might look at hiring one for the job. Or just do it up FT!!
#6 maccers
maccers
  • 1,875 posts
  • Local Club: LSMOC
Posted 24 July 2011 - 04:54 PM
Looks like this - http://www.halfords....tegoryId_165469
#7 maccers
maccers
  • 1,875 posts
  • Local Club: LSMOC
Posted 24 July 2011 - 04:58 PM
;D just pushed the drive and it popped out, never knew it done that. Will go and get one with a bigger range on it.
Thanks for that GW and Ickle....
#8 ibrooks
ibrooks
  • 1,017 posts
Posted 25 July 2011 - 10:02 AM
Just for reference - quite a lot of torque wrenches just won't do left hand threads. I've got a Draper and a Teng click type that won't despite being the ratchet type and the ratchet mechanisms are reversible. I've got a much older Draper that has a dial to show the current torque being applied and that has a 3/8" square sticking out both ends of the head so it'll work in either direction.
Then there's my Britool torque wrench..... It's not a ratchet and the 1/2" square will push through the head to torque things in either direction. It's of a size that's more usually seen tightening the wheel-nuts on buses and artics. Ideal for the front hub-nuts though.
Iain
#9 MRA
MRA
  • 7,607 posts
Posted 25 July 2011 - 10:18 AM
Torque wrenches should never be used to "undo" anything.... as it screws up the calibration.
#10 maccers
maccers
  • 1,875 posts
  • Local Club: LSMOC
Posted 25 July 2011 - 11:10 AM
Yep, indeed, I have an old knackered Draper wrench I use as a breakder bar undo helper. The Halfords one only allows one way tightening, unless you take the drive out and put it on the other way, that I discovered yesterday.
I also read somewhere when not in use to slacken them right off to maintain accuracy etc.
#11 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 25 July 2011 - 11:29 AM
Correct
