Custom Steering Column
Posted 27 July 2011 - 12:25 PM
also what is the spline type on the steering rack as i need to get some uj's to fit this.
i have looked on car builders and they sell splined shaft but it seems like a waste as i will need to cut these down and they only have one splined end and i need more than one. also the ujs are to big for my application i need slim line ones.
Posted 30 August 2011 - 06:10 PM
Posted 28 August 2014 - 02:28 PM
Bump purely out of interest!
Posted 28 August 2014 - 02:30 PM
Why not make a sleeve instead of splines. Use a suitable pin or bolt going through the inner column and outer sleeve?
Posted 29 August 2014 - 07:33 AM
I've heard early fiesta UJs are the correct spline. How true this is I don't know.
Posted 29 August 2014 - 09:25 AM
I've seen some specs somewhere, probably on here. Afraid I can't remember, but I do recall it's common to many cars and the same as one of the aftermarket UJ's.
A scrapyard raid with a hacksaw is probably your best bet
Posted 29 August 2014 - 11:09 AM
IIRC it's an MOT fail?
I could easily be wrong...
Posted 29 August 2014 - 11:50 AM
Slimline. Why not just consault an engineer and figure out if cross bolting is a viable option. No welding needed then.
Also these guys
http://www.unisteer.com
And more treasure from a cursory internet search.
http://www.theminifo...ck-spline-size/
Edited by 69k1100, 29 August 2014 - 12:04 PM.
