Edited by JacPowell, 30 July 2011 - 09:19 AM.
Posted 29 July 2011 - 06:11 PM
Posted 29 July 2011 - 07:23 PM
Posted 29 July 2011 - 08:23 PM
Posted 29 July 2011 - 08:27 PM
Posted 29 July 2011 - 08:28 PM
Check the earth strap from bulkhead to engine hasn't frayed through. this will cause a problem when the engine moves like when changing gear.Hi there, i have a 1991 Studio 2, ive had it about 4 weeks now with no problems until yesterday, the revs started dropping and it started coughing and spluttering. I though it may just have been temporary but became intermittent and is now a permenant feature. Basically it starts up ok but when im going through the gears 3rd into 4th particularly when the revs are up it basically starts spluttering and it cuts out, now i had the recovery truck come out but he couldnt find anything wrong with it (apart from the exhaust blowing) and a little oil needed in the carb ( which i did when home ) I took it to Thornton Mini Spares in Bradford today but they said it could be anything and to leave it until it gets worse
Now thats the most crap ive ever heard from a garage, i need this sorting asap so if anyone could help it would be great, Thanks
Posted 29 July 2011 - 08:40 PM
Posted 29 July 2011 - 08:51 PM
Sorry its just i need this fixing asap. Anyway Pipes are fine checked them all no leaks or splits or anything, plugs are practically brand new and colour is spot on, the guy at the garage mentioned the points and condenser but wouldnt do it till its practically stopped
havent checked the earth strap will have a look as soon as, where abouts is it though ( first car/mini ) and it coughs and slows down but if i give it gas it tries to pick up but then slowly cuts out if that makes sense.
Posted 29 July 2011 - 09:02 PM
Posted 29 July 2011 - 09:40 PM
Posted 29 July 2011 - 10:09 PM
Ah the condenser sounds feasable as when it does start to splutter if i come off the throttle it picks up again, does that sound possible ? Please dont say it could be allsorts
had a very similair problem with my motorbike ending up spending a very hefty amount of some fixing literally everything and it still had the same problem
Posted 30 July 2011 - 09:35 AM
Posted 30 July 2011 - 08:38 PM
Posted 30 July 2011 - 10:45 PM
Just to let you all know its sorted ! Was a combination of the following: No oil in carb, Condenser, Points and Exhaust leaking, feels like ive gained a few horses too, Bonus !
