1380 Mpi. Which Battery?
6 replies to this topic
#1 jamesmpi
jamesmpi
  • 1,940 posts
Posted 01 August 2011 - 04:52 PM
I've done some searching through the forum and have seen some recommendations for using a Peugeot 306 battery as it provides more cranking power on start up. Is this a good option for a 1380 mpi?
My current battery in knackered and I have the mot due at the end of the week so need a decent battery.
#2 jamesmpi
jamesmpi
  • 1,940 posts
Posted 01 August 2011 - 05:08 PM
I should point out the my mpi is not a cooper. V5 states it simple as an "mpi" so it's a non sportspack model (w reg)
#3 Wakey-Dan
Wakey-Dan
  • 256 posts
Posted 01 August 2011 - 05:40 PM
I believe the biggest battery that Will fit in the box is an 063. that's what Im currently using and it works a treat.
#4 jamesmpi
jamesmpi
  • 1,940 posts
Posted 01 August 2011 - 06:03 PM
063? Where did you buy that one from? What make is it?
#5 bcjames
bcjames
  • 2,728 posts
Posted 01 August 2011 - 06:09 PM
063 is a generic battery spec. I have a Bosch Silver S5 063.
#6 jamesmpi
jamesmpi
  • 1,940 posts
Posted 01 August 2011 - 06:27 PM
Cool thanks for that
It's spec says 520amps for cold cracking and apparently standard mpi needs 265 amps so that should give it the extra kick to get it fired up ;)
Edited by jamesmpi, 01 August 2011 - 06:39 PM.
#7 L400RAS
L400RAS
  • 2,479 posts
  • Local Club: Lincolnshire Mini Owners Club
Posted 01 August 2011 - 07:45 PM
Type 075 will fit. Gets you to 540 cold amps. Used for pug diesels, so should crank a mini...
