Faulty Tachometer
8 replies to this topic
#1 mini-thomas
mini-thomas
  • 70 posts
  • Local Club: YDCCC
Posted 02 August 2011 - 08:55 PM
1991 Mini Cooper (MG Metro engine)
My tacho (rev meter) is not reading correctly. I have had a snap on timing light on it, that read correctly i presume while my clock didnt.
Could anyone shine any light on any common faults or where about to check?
Regards
Thomas
#2 mini-thomas
mini-thomas
  • 70 posts
  • Local Club: YDCCC
Posted 04 August 2011 - 07:13 PM
Anyone?
#3 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 04 August 2011 - 07:38 PM
faulty wiring/connections or a faulty coil
#4 Tarmac Animal
Tarmac Animal
Anyone?
Have you checked the wires and connections for it on the back?
I found that there is a little pin type thing that the tacho wire plugs into at the back on the tacho that was loose so i took it apart and tightened it up and it was working great again.
#5 Kam
Kam
    Straight to the Point
  • 4,140 posts
  • Local Club: 16vMini club
Posted 04 August 2011 - 07:40 PM
What gauge are you using? And whats "not reading correctly"
wrong revs to what your reading? erractic jumping? did you buy the gauge seperately? taken the needle off to change the fascia beforehand?
#6 mini-thomas
mini-thomas
  • 70 posts
  • Local Club: YDCCC
Posted 10 August 2011 - 08:34 PM
Cheers guys. The revs are steady and not erratic but reading below what they should be. I'll check it out soon, haven't had chance with the weather being the way it is.
#7 myredmini
myredmini
    My Mummy Says It's OK
  • 3,211 posts
  • Name: Dan
  • Local Club: BOG MOG
Posted 23 August 2011 - 06:56 PM
I'm having this problem. Mines reading over. Will post up what it was when it's fixed.
#8 1984mini25
1984mini25
  • 8,785 posts
Posted 23 August 2011 - 07:00 PM
The needles do pop off quite easily with the aid of a fork, could just pop them of and move it round and bit.
#9 L400RAS
L400RAS
  • 2,479 posts
  • Local Club: Lincolnshire Mini Owners Club
Posted 24 August 2011 - 06:25 AM
Isn't there an adjustment screw on the rear to do this?
