Spanner Size Needed To Adjust Hi Lows?
7 replies to this topic
#1 rich1889
rich1889
  • 285 posts
  • Local Club:
Posted 03 August 2011 - 10:29 AM
Just post i guess
Edited by rich1889, 03 August 2011 - 10:30 AM.
#2 tom3112
tom3112
  • 346 posts
Posted 03 August 2011 - 10:32 AM
i just used my hand?
#3 Notay
Notay
  • 153 posts
Posted 03 August 2011 - 12:09 PM
Just post i guess
i used a 32mm spanner
#4 Mini_Magic
Mini_Magic
  • 5,747 posts
Posted 03 August 2011 - 12:14 PM
+1
You should be able to just adjust them by hand once the car is jacked up, may have to apply a bit of pressure to the front wishbone/rear trailing arm. Upwards for the front and downwards for the rear.
Or just use a 32mm open ring spanner as above.
Edited by Mini_Magic, 03 August 2011 - 12:16 PM.
#5 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 03 August 2011 - 01:47 PM
On HILO's there should be a lock nut which will prevent the shaft from turning...
If you can adjust them by hand then there's a bit missing.
Personally I use a pump wrench, one size fits all.
#6 E.L.M.O
E.L.M.O
  • 3,953 posts
Posted 03 August 2011 - 03:40 PM
same here. I just use my adjustables on them
#7 L400RAS
L400RAS
  • 2,479 posts
  • Local Club: Lincolnshire Mini Owners Club
Posted 03 August 2011 - 03:47 PM
Just post i guess
Genuine hi-los are 32mm i believe, however non genuines can be any size going! (Minisport adjusta rides = 1 inch AF.)
#8 adam davies
adam davies
  • 212 posts
Posted 03 August 2011 - 03:50 PM
It's BIG! I know that. 32 sounds about right and I could turn mine by hand as well but it would do anything. The nuts should be tight together for it to adjust the ride height
