Brake Unions
5 replies to this topic
#1 josh.goddard
josh.goddard
  • 398 posts
  • Local Club: Derbyshire Classic Mini Club
Posted 03 August 2011 - 08:58 PM
got some brake unions from work but they don't fit what sort of unions do i need??
#2 ibrooks
ibrooks
  • 1,017 posts
Posted 04 August 2011 - 08:31 AM
The correct ones.
What sort did you get from work? Where do you work? (might give us a clue as to the first question). In what way do they "not fit"?
Most of the fittings on the Mini are 3/8UNF. Most modern cars will use M10x1mm but it's not a hard and fast rule - there's always that rogue out there that uses something completely different.
Iain
#3 MRA
MRA
  • 7,607 posts
Posted 04 August 2011 - 09:32 AM
The sizes used on the Classic Mini are.....................
3/8"unf
M10x1
M12x1 (Only Yellow tag master cylinder though)
However as above the majority are 3/8"unf
Also you have male, female and different seats so for each size you could have 4 combinations (except the M12x1 as there is only one type used)
Making a total of 9 different flare ends.
#4 munkey26
munkey26
  • 267 posts
Posted 13 October 2012 - 01:59 PM
3/8"unf
M10x1
Does anyone have a list of how many of each is required? I.e. how many female unf, how many male unf and how many male/female M10?
This is for an MPI mini but would imagine this is the same for all Minis 94 onwards?
#5 tiger99
tiger99
  • 8,584 posts
Posted 13 October 2012 - 02:57 PM
The best thing is to examine your actual car carefully.
#6 munkey26
munkey26
  • 267 posts
Posted 14 October 2012 - 06:58 PM
I could do, but the Mini has been around so long that I thought someone may know :-)
