Year: City E
Was driving along today, and thought I could smell burning. I just put it down to it being a Mini, and always have some sort of odd noise or smell to accompany me on the journey.
It was bucketing down whilst I was driving, I had the sat nav plugged in, the wipers going, the lights on, and obviously the stereo on with my iPod plugged in through an auxiliary input, if any of this makes any difference.
I've got some pictures of what it looks like now:
This was the block connector that went in to another block connector, which then went in to the stereo. The wire from the other connector to the stereo didn't melt away like this, but it is a bit melted/warped at the ends.
This is the connector on the back of the actual stereo, as you can see the top right is where it got pretty hot.
This is where the earth wire went to. The wire melted and split in half, and it's the ring connector on the very bottom of this photo. I don't know if having five things earthed on the same point has anything to do with this problem?
Close up of the ring connector.
This was the last burn mark on the red and yellow wires, about half way along until they connect up to the loom under the steering column.
If anyone could tell me what happened here, and how to stop it from happening again, I would very much appreciate it! Obviously I'm going to need some new bits to replace the damaged part of the stereo harness, but no point getting anything just to have it melt again.
I think I was lucky that it wasn't any worse...
Cheers guys, Sven.
