Changing Rocker Cover
Posted 06 August 2011 - 04:16 PM
After reading the engine detailing thread im looking at changing my rocker cover to a chrome version. Are these easy to change? Just a case of getting the seal and line up right isnt it?
Cheers Mike
Posted 06 August 2011 - 04:26 PM
You'll need a new gasket and depending on the type of rocker cover your getting you might need some RTV sealant to 'glue' the gasket to the cover to stop it moving when you put the rocker cover on.
Posted 06 August 2011 - 04:33 PM
Posted 06 August 2011 - 10:00 PM
Yeah, easy to change, but over time they can be sticky after the fixings are removed, due to the gasket sticking to the head etc. Do not be tempted to lever it up where the flange joins the gasket, you will only damage it.
Instead, give it a light tap in opposite directions on the corners with a soft mallet. Just light taps on the corners will be enough to dislodge it. Dont tap anywhere else or it may be damaged.
Edited by mk=john, 06 August 2011 - 10:05 PM.
Posted 06 August 2011 - 10:09 PM
Yeah easy to change, may aswell check and adjust your tappets while you've got it off.
How do i check and adjust and what are my tappets? lol still getting used to everything
Thanks again for the advice. Any sealents you guys would reccomend?
Cheers Mike
Oh and also my cap is in the centre of my cover. Does the new cover have to have the cap in the same place? May be a stupid question again but better to check
Edited by Brookesy, 06 August 2011 - 10:15 PM.
Posted 06 August 2011 - 10:11 PM
yes i agree n you will need either some sealant or about 5min before you change the cover put the gasket around your head lol that usually works
The head of the engine or your actual head?
Its worth changing the 'T' bars too as it finishes of the whole look
Silicon Selant works fine, but you also get specail gasket selant
Edited by AlexMozza, 06 August 2011 - 10:12 PM.
Posted 07 August 2011 - 01:50 PM
You should get a service manual if you don't have one. The procedure will be described in detail there. The manual may also describe the "rule of 9" which tells you which valves can be adjusted at the same time. It's not a hard process to adjust valves but while the cover is off it is indeed a good time to do it.
As for the new valve cover, there are some minor things I do when fitting them that may help you. Rocker covers are often warped or deforrmed from being over-tightened. On the other hand, the top of the head is flat. When fitting the new parts, thoroughly clean and degrease the gasket seat on the cover and the corresponding surface on the cylinder head. Then apply a very THIN film of grease all the way around the perimeter of the head where the gasket will sit. Returning to the valve cover, apply RTV to the surface where the gasket sits, fit the gasket gently making sure there is contact with the RTV all the way around. Fit the cover/gasket to the cylinder head and tighten the mounting bolts/nuts finger tight. Allow this to sit for a few hours (at least... if not over night) then tighten the gasket properly once the RTV has cured. The RTV fills the gaps/voids between the gasket and cover while the other gasket surface conforms perfectly to the flat surface of the head. You should find no leaks and minimal torque will be required to secure the cover and achieve the seal.
Posted 07 August 2011 - 04:15 PM
Thanks once again much appriciated:)
Mike
Posted 08 August 2011 - 06:54 PM
