I had what I thought to be a leaking primary gear oil seal but on removing the primary gear I have found that the front bush has "picked up" and a lot of the bronze material is missing and is probably the cause the oil seal leak. On talking with MED, their opinion was that replacing the fixed bush with a fully floating item is the way to go, which is backed up by the Mini Spares brochure.
Before I go ahead and order one I would like to know of anyone who has had experience with these bushes and are the cure all that they are claimed to be? Also, what is the best way of removing the damaged bush from the primary gear?
Edited by pogie, 08 August 2011 - 05:10 PM.
