Corroded Front To Rear Brake Pipe
4 replies to this topic
#1 hulsmeier
hulsmeier
  • 158 posts
Posted 11 August 2011 - 07:04 PM
I have a 94 spi, my car failed on many things on the mot one being a excessively corroded brake pipe which runs from th front to rear. I was just wondering if anyonecould tell me where the front part of the pipe attatchs, it seems to run down the bulkhead but i cant tell where it joins. also is this a hard one to get moving, just replaced a fuel pipe which had very badly siezed unions. =s cheers
#2 Youngowner93
Youngowner93
  • 426 posts
  • Local Club: Durham Mini Club
Posted 11 August 2011 - 07:12 PM
it connects to a valve underneath the brake servo on the drivers side from there it runs underneath the car. Shouldnt be difficult to move if you soak the pipe ends in some penatrating fluid for a while. As long as the ends dont round off you should be fine.
#3 hulsmeier
hulsmeier
  • 158 posts
Posted 11 August 2011 - 07:16 PM
thanks mate, ill give it a soak now so its ready for tomorrow.
#4 minimender
minimender
  • 1,589 posts
  • Local Club: M.M.M.
Posted 11 August 2011 - 09:40 PM
If you break anything then these people do all the bits you will need including the flaring tool for the pipe ends.
http://www.vehicle-w...pipe/brakes.php
#5 robtheplod
robtheplod
  • 960 posts
Posted 12 August 2011 - 06:40 AM
www.dsnclassics.co.uk do a reasonable priced set for the whole kit.
