How many liters of oil does an Mpi take? Do I need a special seal for the oil drain? It's been about 2 years since I've done a change.....but don't worry because the car has been sitting most of the time, only done a maybe 200 miles, and the oil still looks good but I'm going to change it anyway because of the time that has passed.
Oil Change Requirements
mr.x
, Aug 14 2011 05:30 PM
2 replies to this topic
Posted 14 August 2011 - 05:30 PM
Posted 14 August 2011 - 06:01 PM
i think its about 5 liters can you will need i think thats the halfords classic oil and you have little left over. if the oil is black then it should really need to be changed and its only a copper washer i would of thought it be the same for all mini engines anyways
Edited by greensilver mini, 14 August 2011 - 06:08 PM.
Posted 14 August 2011 - 10:39 PM
5 litres should be plenty. Be sure to replace the copper seal on the sump plug with a new one, or you'll surely get a tiny leak from it.
