Why Is There Some Kind Of Capacitor On The Coil Bracket?
6 replies to this topic
#1 northy
northy
  • 204 posts
  • Local Club: LCMOC
Posted 16 August 2011 - 11:46 PM
I've wondered this for a while but i really must know, why is there a little barrel with a wire coming out of it attached to the ignition coil bracket? the wire is connected to one of the coil terminals (not sure which one after removing coil for cleaning) and there is "AMPOHM 1uf 150v" written on it, which looks like a capacitor code?
Any clues?
And should it connect to + or -, and what effect will doing it wrong have?
Thanks folks.
#2 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 17 August 2011 - 12:23 AM
It's the ballast I believe:
http://www.minispare...ty=pb&pid=34434
#3 northy
northy
  • 204 posts
  • Local Club: LCMOC
Posted 17 August 2011 - 01:24 AM
mine looks very, very different to that...
and mine earths itself and only has one wire.
Also i have electronic ignition so it's unballasted...
IT can be seen here, on the top bit of the bracket. Posted Image
#4 new_zealand _minis
new_zealand _minis
  • 654 posts
  • Local Club: wellington new zealand
Posted 17 August 2011 - 06:31 AM
ive got one on my metro was there so i left it there .. it is called a condenser ... if its doing no harm let it be !
#5 ShoutforJoy
ShoutforJoy
  • 738 posts
  • Local Club: TMF+, Automatic Mini Register
Posted 17 August 2011 - 06:34 AM
It's a suppressor. It helps to reduce interference between the ignitions circuits and your radio (or other ICE). Usually attached to the +ve side of the coil - connecting it wrong will probably just render it non-functioning. Disconnect the wire it and see if you have any interference, if not you don't need it - if you do have interference reconnect it.
#6 lolipop
lolipop
  • 151 posts
Posted 17 August 2011 - 06:59 AM
Ditto what he said. Took mine off, didn't make any difference.
#7 R1minimagic
R1minimagic
  • 4,660 posts
Posted 17 August 2011 - 08:37 AM
That's my pic you stole!
