I am selling this suspension if any ones interested details are as follow,
SPAX adjustable ride height and stiffness dampers are 28 stage on-car adjustable. The dampers are adjustable in both bump and rebound stiffness, giving ultimate adjustability and performance tuning. SPAX engineers have developed these dampers to produce maximum comfort, control and handling. SPAX adjustable dampers are pressurised with Krypton gas. This produces not only superior low speed ride quality, but also high speed performance that is ultra stable, fade free and therefore significantly improved. The result is maximum comfort when you need it or maximum performance when you want it. SPAX adjustable dampers are ideal for all road applications and for track day use, because they have a wide range of on car adjustment with no dismantling. Transform your car’s handling from “Sunday Drive” to “Track Day” in about a minute!
SPAX adjustable dampers are designed and manufactured to the strictest German TüV quality standards, using the latest technologies and methods. Each and every SPAX adjustable damper is fully Dyno Tested to ensure you get 100% performance, 100% quality, 100% guaranteed. All SPAX adjustable dampers are Epoxy Powder coated and oven cured for second to none looks and extra long life.
£300 plus postage if needed
