Beeping Coming From Dash
Ayaluv
, Aug 18 2011 01:34 PM
8 replies to this topic
Posted 18 August 2011 - 01:34 PM
Hi there
I have a 96 Rover Mini 1.3i
There is an intermittant loud beeping noise coming from the dash area, can anyone tell me what this is about or how to disable it?
Cheers!
Cheers!
Posted 18 August 2011 - 02:12 PM
Is it standard UK spec or a Japanese import?
Posted 18 August 2011 - 02:23 PM
Japanese import
Posted 18 August 2011 - 02:44 PM
Sounds like the warning buzzer for the catalyst temperature sensor and it is getting too hot!
Posted 18 August 2011 - 02:58 PM
Yep what he said. That's the only thing I've heard of on a mini that can beep. Only the Jap spec models had them.
Edited by benb12, 18 August 2011 - 02:59 PM.
Posted 18 August 2011 - 03:06 PM
What's the solution? Does it need a mechanic?
Posted 18 August 2011 - 03:07 PM
Dont disable it, it is there for a reason to tell you something is wrong.
The cat could be sooted up, the substrate could be melted or broken or there could be a problem with the engine management. Best to find out what the problem is rather than just ignoring it!
Posted 18 August 2011 - 03:17 PM
Ok, thanks a million for your help!
Posted 08 November 2011 - 08:03 PM
My first car was a mini neon and I remember having a beeping noise coming from the dash, I think it was to do with the beaks tho, because the master cylinder was buggered. I ended up driving it into my mates gates as the pedal went straight to the floor. not fun.
