Srs Airbag
7 replies to this topic
#1 stevo1
stevo1
  • 16 posts
Posted 18 August 2011 - 02:32 PM
Hi,
I am all new to the mini world Ive just bought a 97 rover mini cooper and I was hoping someone on TMF could let me know firstly why my SRS light is flashing and secondly how I can fix the issue.
Any help would be much appriciated!
Stevo
#2 Pitcrew6464
Pitcrew6464
  • 1,673 posts
Posted 18 August 2011 - 02:35 PM
Hi Stevo pritty sure you will need to get it reset using a OBD reset tool abot £10/15 on ebay, then if it comes back on there maybe a problem with the actuall airbag, but could be a cheap fix.
#3 R1minimagic
R1minimagic
  • 4,660 posts
Posted 18 August 2011 - 02:37 PM
Hi,when is it flashing? It is supposed to come on constantly when you first start the engine and then go off after a few seconds.
It might just be the connections on the yellow loom,but make sure you disconnect the battery for at least 30mins before touching anything.
There are 2 connectors on the steering wheel end and a single large red plug on the ECU module under the drivers side rear seat.
#4 stevo1
stevo1
  • 16 posts
Posted 18 August 2011 - 04:11 PM
Pitcrew,
Thanks for the advice I will grab a OBD tool as the first option
#5 icklemini
icklemini
  • 2,982 posts
Posted 20 August 2011 - 12:49 AM
Dont bother:
1) - the SRS system is not connected to the emissions system (to which the generic OBD readers communicate with)
and
2) - No Rover mini is OBD compliant..
#6 jbonevia
jbonevia
  • 52 posts
Posted 20 August 2011 - 02:33 PM
I would do the following as a starting point:
The airbag ECU is located on the drivers side floor under the back seat. Remove this, disconnect the plug and spray with electrical cleaner, reconnect and re-install ECU to floor.
Remove the rear plastic storage bins from both sides of the car, underneath the bins are the seatbelt assemblies, there is a yellow plug for the seatbelt pre-tensioners which connects to the airbag system, disconnect the plug, spray with electrical cleaner - re-connect.
Remove the airbag from the steering wheel, this is held in by two torx bolts. disconnect the wiring connectors, clean as above and re-connect.
Check the airbag warning light now and see if it is gone.
If not you can also remove the steering wheel and steering column covers, behind the steering wheel is a plastic ring which the airbag wiring goes through, this also needs to be checked, they can break or it may just need the contacts cleaned as well.
#7 bpirie1000
bpirie1000
  • Area Managers
  • 2,376 posts
  • Local Club: Amoc
Posted 16 July 2024 - 04:56 PM
My plan is to check the continuity on these connections like a normal circuit and see if the srs rotary ring is at fault?
Using such as a voltmeter. Obviously with battery off. Airbag module unplugged and airbag away from the circuit completely disconnected?
#8 Midas Mk1
Midas Mk1
  • 5,787 posts
  • Local Club: S.U.N.M.C
Posted 17 July 2024 - 12:08 PM
Whatever you do don't resistance check the airbag connectors - seen it happen at work..
