Aldon Dizzy
13 replies to this topic
#1 minimotivator
minimotivator
  • 28 posts
Posted 19 August 2011 - 07:22 PM
hi
i have just got a used aldon 100arp dizzy for my a plus 1275 i think it has ignitor fitted problem is how does this w3ire in as it has a black and red wire and my standard points dizzy only has one wire ,alsoany idea what cap to buy,also would this need a standard coil or one from a electric ignition,i have both so no problem.this dizzy has no advance pipe so would i just blank that off. any advice will be great thanks lee
#2 bmcecosse
bmcecosse
  • 9,699 posts
Posted 19 August 2011 - 08:17 PM
Advance pipe is essential for sharp response and good economy - I think you have just found all the reasons that made this dizzy available secondhand..... Put it on ebay.......
#3 new_zealand _minis
new_zealand _minis
  • 654 posts
  • Local Club: wellington new zealand
Posted 19 August 2011 - 08:47 PM
you can also put a vac advance on it !!
#4 minimender
minimender
  • 1,589 posts
  • Local Club: M.M.M.
Posted 19 August 2011 - 09:28 PM
Good dizzy for 1275 is an MG Metro one
The advance comes in pretty quick and static can be as much as 13 degrees if you need it (lumpy cam)
Aldon are over rated in my opinion unless specificity profiled for your engine. :)
#5 bmcecosse
bmcecosse
  • 9,699 posts
Posted 19 August 2011 - 09:34 PM
How could one put a vac advance on a dizzy that has no location for it ?? Do please tell!
#6 minimotivator
minimotivator
  • 28 posts
Posted 20 August 2011 - 08:14 AM
hi again
thanks for the info i didnt say my a plus has got a non standard engine fitted with kent 286 cam and lcb highly modded mg miget head that had bigger valves and ported ang polished i just wanted ohe a bit faster for the road ,thanks for info on the coil wiring but not yet sure if mine is ballast or non ballast and need to know which col to fit.its a standard points dizzy on now . i am not to botherd about the vacume unit if it runs ok.i will just have to try it and see thanks lee
#7 new_zealand _minis
new_zealand _minis
  • 654 posts
Posted 20 August 2011 - 08:19 AM
preety simple when all aldon do is put a plate over the hole for the vac advance !! i do know have got one on my desk now ..
#8 Sheikh Pip
Sheikh Pip
  • 239 posts
  • Local Club: Sutton Coldfield Mini Club
Posted 20 August 2011 - 11:57 AM
I might just buy it off you if you if it don't suit your engine, PM me if so!
#9 Cooperman
  • 23,309 posts
Posted 20 August 2011 - 08:33 PM
On the Cooper 'S' a vac advance was never fitted.
Aldon did a custom dizzy for my rally 'S' and it has proved fantastic. I just gave them the full spec and they curved one with no vac adv to suit my spec. Price was reasonable and it's been ultra-reliable, despite running with points ignition (as required for Historic rallying).
#10 Cooperman
  • 23,309 posts
Posted 20 August 2011 - 08:52 PM
I used to run the Aldon Yellow worked fine even with the kent 530 cam (649).
But I've seen the light/future and am now Megajolt'd, which is by far the BEST option. If your not restricted by class regulations.
Yes, Megajolt is the way to go, but I'm not allowed that for Historics.
I had a 286 at 11.2:1 CR, etc, and with an Aldon 'Red' with no vac adv when optimised for top end power on the RR it just would not turn over when hot as the static adv was too high.
Aldon re-curved it and gave me an additional 4.5 degs mech adv and it has proved fantastic over many years of hard use. I change the points regularly, but other than that I've not really touched it. Static advance is 5.5 degrees so it always turns over even when hot with my 530 CCA battery.
#11 jt19
jt19
  • 745 posts
Posted 24 February 2014 - 09:23 PM
Sorry to bring up an old post but how can you tell what aldon dizzy you have? i have one but i can't see any id numbers on it etc.
Will it be better than a electric metro dizzy? as i have one spare?
josh
#12 Stu1961
Stu1961
  • 633 posts
  • Local Club: Still Looking
Posted 24 February 2014 - 09:49 PM
Have just purchased an Aldon put together by them to match my engine spec (A+ Series - Yellow 100AYP) it has no vac advance though I did ask the question
about adding it later if I was not happy with it, good news is it can be easily be added though it requires the baseplate changing as well. Aldon are just 10 minutes from me so Had a pretty in depth chat with the bloke who puts them together, he was extremely helpful.
Stuart
Edited by Stu1961, 24 February 2014 - 09:50 PM.
#13 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 24 February 2014 - 10:46 PM
josh
There should be scribed on the body a number and letters AY is Aldon Yellow and AR is Red - there can be a third letter this identifies the lead output (side/top) and if its a igniter distributor, A+ blocks and drive dogs
And in regard to your second question, depends what the engine spec is, In a standard metro engine the curve will suit that engine, the Aldon wont have the right curve, for a tuned engine the Aldon yellow will be better than the standard.
Edited by KernowCooper, 24 February 2014 - 10:53 PM.
#14 jt19
jt19
  • 745 posts
Posted 25 February 2014 - 09:53 PM
Thanks guys.
I'll have a look tomorrow, It's a 1380 with high compression, big valves and sw10 cam so not standard
Thanks,
Josh
