Can't Get Pushrods Back In After Head Gasket Change
2 replies to this topic
#1 MacroMan
MacroMan
  • 30 posts
Posted 21 August 2011 - 07:44 AM
Hi everyone,
My head gasket went yesterday, so I stripped the top half of the engine down and removed the head. I cleaned everything up ok and placed the head back on over a new gasket, but when I went to drop the push rods back in, two of them are much too high, and I don't just mean high enogh to open a valve, they are really high. It feels like there is something loose in the bottom that I can kind of slide along to the next pushrod hole, so I can place this one ok, but not the next, and vice versa.
The 'object' under the holes, what could it be? I really need to get my car working again today, so any advice is very much appreciated.
Attached File  2011-08-20 20.41.32.jpg   3.29MB   6 downloads
Many thanks
David
#2 Paul Wiginton
Paul Wiginton
  • 1,585 posts
Posted 21 August 2011 - 08:09 AM
I take it this is a 998? If so the cam followers have come out of their guides. Remove the tappet chest covers on the back of the block and pop them back in
#3 kbolitho
kbolitho
  • 40 posts
Posted 21 August 2011 - 03:44 PM
I second the above. When I did mine, I didn't notice anything was wrong until i started the engine and bent 3 of the rods! Popped the tappet covers off and straightened it all out. I found it helped to put the pushrods back in with the covers still off. That way if you knock them off again its easy to sort out.
