When i pull the indicator stalk nothing happens, no lights come on, nor on the dash, however the headlights work when turned on, and permanent main beam works!
Horn/indicators also work....
any ideas? How do i take it apart? Thanks.
Headlight Flasher Not Working
strothow
, Aug 21 2011 03:01 PM
2 replies to this topic
Posted 21 August 2011 - 03:01 PM
Posted 21 August 2011 - 03:58 PM
Easy, (maybe), remove the cowling - two screws. Locate the pull switch for the flash on lhs of stalk, Get a bit of abrasive paper folded in two & place between contacts. Gently pull on stalk to provide friction & gently rub the contacts. This worked for me about a month ago.
Failing that check the fuses are all ok & the wiring on the slam panel. The bullet connectors can work loose.
Posted 21 August 2011 - 04:08 PM
Done it! I typed that out then went for an investigaiton and it was what you said
Thx.
Thx.
