I went to replace my thermostat today, and when I tried to remove the last of the three thermostat bolts the head rounded. I went down one mm in size and tapped the ring end of a spanner on, even then the bolt would not budge and then rounded again. Now the head is as good as circular and the bolt has not budged...
What would people say I should do? I haven't had this problem before...
I'm guessing;
- Cut the hex head off
- Take the housing off
- Try and move the remaining section with two nuts turned together as per a head stud
- If that fails, drill it out and tap a new thread?
