Minisport 1.3 Roller Tip Rockers - Any Good?
10 replies to this topic
#1 colinu
colinu
  • 517 posts
  • Local Club: MOASF
Posted 23 August 2011 - 05:51 PM
Folks,
My rocker assembly has a cracked pedestal and a fair bit of wear. Rather than repair/rebuild it I took the lazy option and ordered a set of 1.3 Roller Tip Rockers from MiniSport. Since then I’ve found a lot of 2 year or older posts on this forum berating the (1.5 and 1.7) rockers from MiniSport… and MiniSport in general.
Note: I don’t want this topic to develop into another “bash MiniSport” thread!
What I would like to know is what is the quality of those 1.3 roller tip rockers like these days? Do they still suffer from premature cracking of the rocker shaft? If so is there any way I can replace/upgrade the shaft (e.g. with MiniSpares heavy duty shaft)?
Cheers,
Colin.
FYI… my old assembly is not roller tip... it uses pressed steel top welded 1.3 ratio rockers (I kind of like them). I don’t particularly need roller tips, but the MiniSport item seemed to be the most cost effective way of replacing them (be they standard or roller tip assemblies).
Edited by colinu, 23 August 2011 - 08:24 PM.
#2 colinu
colinu
  • 517 posts
  • Local Club: MOASF
Posted 25 August 2011 - 12:40 AM
Bumpty bump bump bump...
#3 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 25 August 2011 - 06:18 AM
not heard of anything bad about the quality of there rockers (i have the 1.5's) but they aren't going to do anything to your engine a set of standard rockers wouldn't do for their extra money
they will give you about 0.5 more valve lift and a bit less valve stem ware
#4 colinu
colinu
  • 517 posts
  • Local Club: MOASF
Posted 25 August 2011 - 06:53 AM
Thanks for the reply Bungle - very reassuring :)
The only reason I chose these roller tip rockers is because my cam works best with 1.3 ratio... and I couldn't find anyone selling standard 1.3 rocker assemblies.
#5 new_zealand _minis
new_zealand _minis
  • 654 posts
  • Local Club: wellington new zealand
Posted 25 August 2011 - 08:20 AM
i think most of the std type are not 1.3 more like 1.2 bla bla... so you might get a little more but not much
#6 jaydee
jaydee
  • 8,565 posts
Posted 25 August 2011 - 09:04 AM
There are rumors about everything coming from minisport..like rockers, camshafts etc..
Dont warry about rumors and ask directly to people, like you're doing now.
I know for sure that at ML motorsport they use minisport 1.3 roller rockers, so quality shouldnt be bad.
I'm getting a set too, as i need to replace my worn sintered rockers and at minisport price is quite good..
Standard rocker ratio is in the 1,21/1,22 range, while i read somewhere that the minisport 1,3 rollers are actually 1,27.
Dont expect any mega power boost, but this is about the optimal ratio, a good thing for optimal performance without putting too much extra stress, plus rollers saves valves from side loading and they're a bit lighter also.
#7 colinu
colinu
  • 517 posts
  • Local Club: MOASF
Posted 25 August 2011 - 06:37 PM
It's reassuring to know that ML use them... especially since the cam I fitted came from them (an AC Dodds 'ACD-RS+').
#8 Pigeonto
Pigeonto
  • 973 posts
  • Local Club: ISMOC
Posted 25 August 2011 - 06:57 PM
They are what I have and I dont have any problems,done thousands of miles.As said,they ensure you get the valve lift claimed by the cam grinder- well a bit more probably.
Edited by PIGEONTO, 25 August 2011 - 06:57 PM.
#9 TopCatCustom
TopCatCustom
    Previously known as C4NN0N.
  • 1,134 posts
Posted 25 August 2011 - 08:49 PM
They are basically the proper parts for the job, where standard rockers are a compromise. Because price was a factor on std equipment there was no roller tips, that means more friction and side loading of the valve stems in the guides, which roller rockers eliminate. As already said, dont expect any real performance gains, it's only racing where you could notice any difference and your valve guides won't wear as much with them fitted.
#10 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,149 posts
  • Name: Sean
Posted 25 August 2011 - 09:01 PM
MED do a set of 1.3 ratio rockers.
#11 minicb
minicb
  • 1,131 posts
  • Local Club: south-central-mini-club.com
Posted 26 August 2011 - 12:34 PM
I had a set of rockers from mini sport and they broke twice so they went in the bin. I now have the 1.5 LD rockers from MED
Edited by minicb, 26 August 2011 - 12:38 PM.
