Timing further away than i go on hol!!
Posted 28 January 2006 - 03:45 PM
Could this be down to wrong distributor?
Gaz
Posted 28 January 2006 - 03:47 PM
Posted 28 January 2006 - 03:49 PM
Posted 28 January 2006 - 03:57 PM
line up with the mark on the pully cover
as have had pullys that don't line up before
if not mark the pully when at tdc
cant be the wrong dizzy as any dizzy will work its the advance curve that is
matched to different engines
and that only kicks in as you rev the engine does not afecct the timing on tickover
Posted 28 January 2006 - 04:19 PM
Posted 28 January 2006 - 05:04 PM
Exactly the same as what was wrong( at least one of the faults) with Jackmans, no difference what so ever. Timing arround 60 degrees and burning out caps. Realy surprised it actualy ran :saywhat:
Remove the distributer, use a 5/16 bolt and screw it into the dizzy drive pull it out and turn it one or two teeth clock wise then re install. Fit dizzy and set it up. this will give you enough room to adjust the timing.
Funny thing about JacKmans is that he had the engine tuned on the rollers at minisport and the operator never flagged this up as a problem, just removed the vac advance, said there was too much advance and reprofofiled the needle.
Sorted the timing out three weeks ago and waited to see how things went. Still bad fuel consumption. Today we fitted a different distributer( from a 998), changed the needle in the carb back to the original, found the spring was longer than a standard one(looks like it had been stretched) so changed that too and went for a drive. No hesitation and drove well. Again we shall wait and see if fuel consumption is any better. But now I'm high jacking the thread, Sorry :nugget:
The initial problem was the timming way out, I mean, two weeks and burnt out dizzy cap something was not right
Posted 28 January 2006 - 05:05 PM
It doesn't work, jackman and me tried it just move it two teeth clockwise :cheese:just checked the dizzy driveshaft and according to haynes it is spot on in the right place
Posted 28 January 2006 - 05:25 PM
Gaz
Posted 28 January 2006 - 06:39 PM
Someone giv sprocket a bone!
Gaz
Posted 29 January 2006 - 12:10 AM
Posted 29 January 2006 - 12:19 AM
Posted 29 January 2006 - 12:20 AM
I think you'll find I was right :smartass:Looks to me as though theres a manufacturing error as regards to the timing marks, are the dizzy and crank pulleys origional to the engine or replacments?
Posted 29 January 2006 - 12:24 AM
Posted 29 January 2006 - 12:25 AM
Are you confused
Edited by Mini Sprocket, 29 January 2006 - 12:33 AM.
Posted 29 January 2006 - 01:05 AM
