Computer Blue Screening
Posted 29 August 2011 - 09:59 AM
This one has got me really baffled and im giving up all hope of ever sorting it. Basically when im playing any sort of game on my PC about 10 mins in the computer will blue screen and shut down instantly no matter what graphics settings it's on. I've tried updating drivers, running a check disk, reinstalling games, defrag, Windows repair tool, registry cleaner, Virus scan, disabling everything not necessary. Pretty much everything you get the picture. Im a PC techy myself and this one has really stumped me.
Anyone have any suggestions?
(Im running XP by the way)
Posted 29 August 2011 - 10:27 AM
Posted 29 August 2011 - 10:34 AM
Posted 29 August 2011 - 10:42 AM
Posted 29 August 2011 - 11:36 AM
Posted 29 August 2011 - 11:42 AM
Blue Screen disappers to quickly for me to even see whats written, however i cant remember if it's stored in one of the error logs?
You can make the blue screen stay showing until you dismiss it
![=]](https://www.theminiforum.co.uk/forums/public/style_emoticons/default/sideways.gif)
Posted 29 August 2011 - 12:13 PM
Have you tried reseating the RAM modules? I've had that problem before, where it seems to be a complex problem but the solution was just to take the RAM out and put it back again; I think it can be caused by small amounts of dust getting into the DIMM slots, which causes small problems for the electrical current. Give your system a good de-dusting while your at it, dusty cases are horrible
There's an option in BIOS setup to make blue screen error messages stay until you choose to restart the system.
Posted 29 August 2011 - 12:26 PM
Posted 29 August 2011 - 12:40 PM
Ivan
Posted 29 August 2011 - 01:02 PM
I had it happening with my old system because there wasn't enough memory, 2gb just wasn't enough for some of the modern games running under Windows 7. How much RAM have you got? Try bring up task manager when in a game to see how much memory the system is using.
Got 4GB of RAM should be more than enough for anything im trying to run surely?
Card looks fine at temperature it's getting nowhere near a state where it would be overheatingnot overheating is it? used to get that a lot with mine when i used to play games on it.
I was having a similar problem playing 3D games. I would get the blue screen and the data dump with some message about an ATI file. Tried different drivers and the graphics card in another computer and it did the same thing. It turned out that the card is bad. It appears that it will work OK on regular 2D stuff. This was my newest and best card. Now the computer it is running fine with an older card. It is all AGP and I am not spending any more money on that.
Ivan
Card has been replaced already after i had a faulty unit, has been fine for 3 years it's only just started doing this however
Will give it a good clean out now and see how it improves, even though it was cleaned out 2 weeks ago.
Posted 29 August 2011 - 03:53 PM
Edited by mini77, 29 August 2011 - 04:05 PM.
Posted 29 August 2011 - 04:19 PM
if you can try a different vid card and RAM see what happens then..also are you o/c your system?
Nah im not O/C, think i may have solved it for the time being though. I turned 'Write debugging infomation' off and it seems to have no further issues with blue screening?
Posted 29 August 2011 - 04:25 PM
cool keep us all informed
Posted 30 August 2011 - 07:58 AM
Posted 30 August 2011 - 11:45 AM
