Bonnet Straps/pins
6 replies to this topic
#1 Mini alec
Mini alec
  • 136 posts
  • Local Club: not yet
Posted 30 August 2011 - 12:08 PM
Hi all. looking for either bonnet straps or possibly pins maybe? so after pics, opinions and suggestions please
#2 Magic jason
Magic jason
  • 522 posts
Posted 30 August 2011 - 01:54 PM
I have pinned my bonnet in all 4 corners instead of using straps at the front, i prefer the look and it does the same job, and the bonnet its a lot quicker to get off and on with pins instead of straps. fitting the pins is a lot harder thou as if you want it done properly then you will need to get brackets welded up in each corner compare to just bolting on the straps, or you could bolt the brackets in place but its more of a temporary job rather than a permanent one ;D
#3 jaydee
jaydee
  • 8,565 posts
Posted 30 August 2011 - 03:44 PM
The 'corners' can also be fitted with rivets. Make sure the pins are fitted at a 45° degree angle, have a search on the forum there should be a thread about fitting pins with detailed pics.
I have bonnet hooks at the front, again riveted to body panel and bonnet.
#4 BenCoul
BenCoul
  • 317 posts
Posted 30 August 2011 - 04:06 PM
I have strapps on the front and pins on the back, i prefere the pis more, although i dod mess up drilling the holes so the bonnet sits slightly wonkey
#5 Artful Dodger
Artful Dodger
    " I AM THE SPECIAL ONE"
  • 4,435 posts
Posted 30 August 2011 - 04:16 PM
pinned on the front only. original hinges, saves taking bonnet completely off all the time and then driving, standing on it. probably the best for road going cars. when working on the side of the road you have to take it off, put it down inside or in the car and then probably stand or drive over it... :P
cheeky picture XD
oh and i positioned the pins downwards so i can just pull them out and not sideways as some i have seen :)
Edited by MiniclubmanGT, 30 August 2011 - 04:17 PM.
#6 abe46
abe46
  • 431 posts
  • Local Club: South Devon Mini Club
Posted 30 August 2011 - 05:56 PM
cheeky picture XD
surely the standard bonnet catch would be sufficient for your requirements then?! :P
Edited by abe46, 30 August 2011 - 05:56 PM.
#7 mike.
mike.
  • 6,176 posts
Thing is though, on a roundnose you can't really do just the front with pins, you'd have to use pins all round. Otherwise as the bonnet comes down on the hinges it'd just hit the pins.
