Grease Is The Word !
6 replies to this topic
#1 Nikral
Nikral
  • 274 posts
Posted 31 August 2011 - 09:04 AM
need to go around the cars grease nipples this week and need to know what the best grease is for doing the job, just have a nornal grease type gun that you fill.
Tony
#2 pierres
pierres
  • 586 posts
  • Local Club: No
Posted 31 August 2011 - 09:08 AM
LM Grease
#3 jaydee
jaydee
  • 8,565 posts
Posted 31 August 2011 - 09:19 AM
I use moly grease.
#4 yellowmonster
yellowmonster
  • 170 posts
  • Local Club: MOCT
Posted 31 August 2011 - 01:51 PM
I use normal yellow-ish bearinggrease which is fine..(for me).
#5 maccers
maccers
  • 1,875 posts
  • Local Club: LSMOC
Posted 31 August 2011 - 02:28 PM
Make sure your nipples are clean before you start!
Seriously though, wipe any grit away or it will just get forced into the joint. I had to replace most of mine as the tiny ball had stuck in place. Replace any bleed valve rubber covers too.
#6 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 31 August 2011 - 05:33 PM
Is that a trade name? :lol:
Moly grease is really the wrong thing to use in the suspension grease points. Moly grease generally refers to CV joint grease, which is designed to be more slippery at high temperatures as the moly disulphide cuts the lithium a bit. It only stays inside the CV because of the sealed rubber gaiter, the suspension points don't have these. If it gets hot enough in thre, the moly grease will soon all leave the joint and it will dry out. So although it is still a grade 2 grease, it's not for universal use. You should be using a general purpose lithium grease such as Castrol LM or Duckhams LB10.
#7 jaydee
jaydee
  • 8,565 posts
Posted 31 August 2011 - 08:07 PM
Never thought of that. You always learn something new.
So Moly for CVs and Bearings, lithium for balljoint and top arms.
