Strange Gearbox Selector Problem
Posted 31 August 2011 - 09:23 PM
Had a stiff gearstick (ohh eer misses) - was stiff when selecting 1st / 2nd (left of the vehicle not forward backward)
stripped remote gear selector box - all fine
I have now got gearbox out & the selector shaft is easy to push in/out , but hard to turn to the 1st / 2nd position
I'm thinking bent / clashing selector fork
3rd & 4th are fine as is reverse - it's just stiff to push the stick over to the 1st / 2nd gate
when there it's fine for selecting 1st & 2nd
Any Ideas ??? - no Viagra or Bromide Jokes ;0)
Posted 31 August 2011 - 09:30 PM
Posted 31 August 2011 - 09:44 PM
it's hard to move the stick from the center to the left hand side , when there it wants to stay
but when there selecting 1st & 2nd is easy
It is then hard to move back to center position , but when in center it loosens up
I think I will have to rip out the main shaft to see the problem
Posted 01 September 2011 - 06:40 AM
Posted 01 September 2011 - 09:01 AM
Posted 01 September 2011 - 11:35 AM
Posted 01 September 2011 - 05:31 PM
Posted 01 September 2011 - 06:43 PM
Posted 01 September 2011 - 06:45 PM
If you want to be a bit of a bodger about it, I suppose there is a faint possibility that you could remove the reverse shaft and then with a punch try and hit the bush back in, but you're really going to mess it up and probably will not get the shaft back in...
Edited by Guess-Works.com, 01 September 2011 - 06:48 PM.
Posted 01 September 2011 - 06:48 PM
Posted 01 September 2011 - 07:17 PM
got reverse gear out
can see the reverse selector riding up a bit
with reverse out , the selector shaft feels ok
so tomorrow the main-shaft is coming out
thanks for the tips everyone
Posted 04 September 2011 - 02:15 PM
Reverse idler bush is your problem, it's worked it's way out of the gear and is causing a misalignment of the select pivots which causes a stiffness when moving the gearstick across the gate.
Spot on
That was the problem - thanks
anyway of stopping it happening again ??? - I guess gentle reversing
I see there has been some locktite - or similar on the gear bearing
also noticed the first motion spigot bearing had 2 rollers missing - but no damage - so must have been like that from new
will now need new bearing
thanks everyone for your help
