Edited by danny_rye, 02 September 2011 - 04:56 PM.
Trolley Jack?
Posted 02 September 2011 - 04:56 PM
Posted 02 September 2011 - 04:59 PM
Posted 02 September 2011 - 05:18 PM
Posted 02 September 2011 - 05:46 PM
Personally I would spend the money elsewhere unless you want the jack to last for life.
Posted 02 September 2011 - 06:24 PM
Posted 02 September 2011 - 06:49 PM
Posted 02 September 2011 - 06:53 PM
Posted 02 September 2011 - 07:06 PM
Also, £20-30 on a jack is fine, no point spending more than £50 on one for a minis weight. My last jack was a £20 job my dads had for years, it lasted probably way over a decade before it packed up!
Posted 02 September 2011 - 08:06 PM
Posted 02 September 2011 - 09:04 PM
Don't go cheap on a jack, get a mid quality one like a clarke 3 tonner for about 70 quid and it will everything you need it to. In fact get 2 as you would be amazed how many jobs need more than 1.
also it is alot easier to have two if you were, for example, doing the front breaks, having both wheels off the ground instead of doing one side then putting the wheel back n and then doing the other side:P
Posted 02 September 2011 - 09:28 PM
I prefer to do this with one trolley jack (2-tonner from Halfords) and 2 axle stands.
I have never had an issue with the standard Halfords trolley jack. Mine lasted 15 years before the seals died. My friend's Dad is a former hydraulic engineer and can rebuild them. Then I'll have a spare...
Posted 02 September 2011 - 11:36 PM
Main thing is, don't rely just on the trolley jack itself if your working with it, basic common sense
Posted 03 September 2011 - 12:24 AM
I carry the standard sill jack just incase i ever need to change a wheel at the side of the road, never had a problem with it, and it works perfectly well on any height mini.
Posted 03 September 2011 - 12:32 AM
Posted 03 September 2011 - 08:48 AM
yeah true 8) but where can you jack the whole front of the mini up with one jack without risk of bending the front subframe / valance ?
