10 Inch Steels Over 8.4Inch Brakes
42 replies to this topic
#1 leebob
leebob
  • 161 posts
  • Local Club: menacing moc,rcmoc
Posted 06 September 2011 - 02:16 PM
just wondering if i could put 10 inch standard mini wheels on my project.it has 6x10 weller steels at the minute with 1inch spacers.anybody know if the standards will fit before i buy some and spend money having them powder coated.any info would be great,thanks
#2 Nic
Nic
    Formally known as jonesy!
  • 1,218 posts
Posted 06 September 2011 - 03:12 PM
they will not fit over 8.4 brakes, you will need either drum brakes or 7.5 cooper S disc brakes for them to fit.
#3 R1minimagic
R1minimagic
  • 4,660 posts
Posted 06 September 2011 - 03:14 PM
Some 10" wheels do fit over the 8.4" brakes, JimmyH has done it
#4 jaydee
jaydee
  • 8,565 posts
Posted 06 September 2011 - 03:27 PM
Weller should fit with a spacer and the caliper grinded a bit to have enough clearance..
..not reccommendable for safety, but i've seen it done..
#5 E.L.M.O
E.L.M.O
  • 3,953 posts
Posted 06 September 2011 - 03:29 PM
Yeah some do, but not 10" steels (non weller)
Edited by E.L.M.O, 06 September 2011 - 03:30 PM.
#6 R1minimagic
R1minimagic
  • 4,660 posts
Posted 06 September 2011 - 03:31 PM
His are steels
#7 E.L.M.O
E.L.M.O
  • 3,953 posts
Posted 06 September 2011 - 03:56 PM
Yes they are...... So they wont go over the 8.4" discs
#8 R1minimagic
R1minimagic
  • 4,660 posts
Posted 06 September 2011 - 04:00 PM
Well he's driving round in it!
#9 E.L.M.O
E.L.M.O
  • 3,953 posts
Posted 06 September 2011 - 04:24 PM
Ahhh fair enough. How did he acheive it? Huge spacers, ground back calipers?
(and sorry, when you said "his are steels" I thought you were talking about the OPs! which really confused me!)
Edited by E.L.M.O, 06 September 2011 - 04:24 PM.
#10 TopCatCustom
TopCatCustom
    Previously known as C4NN0N.
  • 1,134 posts
Posted 06 September 2011 - 04:25 PM
I'm pretty sure I got 10" Wellers over 8.4" brakes before with grinding a tiny corner off the calipers
#11 R1minimagic
R1minimagic
  • 4,660 posts
Posted 06 September 2011 - 05:02 PM
I am not sure, he called round for some doors at the weekend, said they were a special offset, have a search on his posts and you will see the wheels he has fitted if that helps
#12 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 06 September 2011 - 05:17 PM
the wheels will not fit over the brakes but will fit outside of the brakes with a inch spacer fitted
#13 E.L.M.O
E.L.M.O
  • 3,953 posts
Posted 06 September 2011 - 06:22 PM
Ahh well that might explain it. Its not the norm to get standard 10" non weller wheels over 8.4" brakes!
Wellers or standard steelies bungle? Because I thought only wellers fitted with the 1" spacer..?
Edited by E.L.M.O, 06 September 2011 - 06:23 PM.
#14 HARBER07
HARBER07
  • 4,498 posts
  • Local Club: Naaa......
Posted 06 September 2011 - 06:26 PM
10x6 Wellers WILL fit OVER 8.4" brakes with a 1/4" spacer and a ground back casting, or OUTSIDE with very minimal grinding and a 1" spacer. Should get the calipers pressure/crack tested after if you do this.
#15 Mini_Magic
Mini_Magic
  • 5,747 posts
Posted 07 September 2011 - 11:31 AM
I've also had 10" wheels on 8.4 brakes, but they had build in spaces to clear the calipers.
You'd also need Sportspack or wider arches with this route.
