how do you fit the c pillar trim panels? are they held in by the rear screen and rear quarterlight seals? or do the seatbelt and window latch hold them on?
cheers
Headlining C Pillar Trim Fitting
ste88
, Sep 07 2011 06:12 PM
3 replies to this topic
Posted 07 September 2011 - 06:12 PM
Posted 07 September 2011 - 07:07 PM
Just looked at my trim panel and it looks like you are are right they fit behind rear and side window seals.
Posted 07 September 2011 - 08:25 PM
As above, they fit behind the seals. There is also a flap that goes under any parcel shelf covering you may have.
Regards
Steve
Regards
Steve
Posted 07 September 2011 - 08:47 PM
thanks for the advice
i've glued it in above the side windows but i still need to pull it tight and glue it in around both screens so i'll put the trim pieces in when i do that
