Would Having A Sump Guard Be An M.o.t Failure ?
Posted 12 September 2011 - 02:22 PM
Posted 12 September 2011 - 02:31 PM
Posted 12 September 2011 - 02:32 PM
I have found an Advisory along with my current MOT on my 07 Passat that mentions the engine cover which is bizarre but nothing about the under tray. So go figure!!
Posted 12 September 2011 - 02:39 PM
Posted 12 September 2011 - 02:43 PM
Posted 12 September 2011 - 04:30 PM
Posted 12 September 2011 - 06:52 PM
Edited by 1275GTS, 12 September 2011 - 06:52 PM.
are you running sump guards?2 of mine have sump gaurds and I haven't had any problems at MOT times.
Posted 12 September 2011 - 07:41 PM
Posted 12 September 2011 - 08:07 PM
yes on 2 minis. they have been on for years. the mot testers have never commented on them at all.are you running sump guards?
Posted 12 September 2011 - 08:09 PM
sorry i dont know why i typed that mustve subconciously been thinking about the thread title, i meant to say are you usig oil coolers?yes on 2 minis. they have been on for years. the mot testers have never commented on them at all.
Posted 12 September 2011 - 08:25 PM
Posted 12 September 2011 - 08:30 PM
fair enough (again apologies for the daft question first time round).no, i'm not running oil coolers on either. i've not had any problems on either. also one of the minis with the sump guard came from japan with the sump gaurd already fitted and its a lot hotter over there than it is here. i'm not saying that you don't need an oil cooler though just that i'm not using one.
i was always told an oil cooler is necessary when running a sump guard. but hey hoe, if it works, it works.
Posted 12 September 2011 - 09:45 PM
On a low-revving engine at higher road speeds (in relative terms) a sump guard may not mean an oil cooler is needed, although it can never be a bad thing so long as the oil doesn't then run too cold in Winter weather (= fit an oil thermostat).
I hope this explains it well enough.
Posted 13 September 2011 - 12:12 AM
thats perfect cooperman, clears everything up perfectly.The issue of an oil cooler on a Mini with a sump guard came about because a sump guard is normally fitted to rally cars. A rally car has very low gearing to maximise acceleration at the expense of top speed and this is combined with a lot of time spent at high revs in the lower gears and relatively low forward speed which thus minimises air flow across the sump fins. Also, a rally car usually has some sort of material between guard and sump which prevents any air flowing under the sump. All this equals high oil temperatures.
